Coolant Overflow - Defender Source
Old October 19th, 2012, 09:14 AM
tdn's Avatar
tdn
Troy Norton
'94 D90
Coolant Overflow
On way to work this morning I started smelling coolant. I watched the temp gage the whole drive (20 min) and it never spiked, just kept smelling it. When I parked I left the truck running and walked around to smell near hood and sure enough there was a steady stream of coolant pouring all over the ground. By the time I walked back around to shut it off, the needle had spiked way up almost into the red. Any obvious indications what the problem may be? Clogged radiator? Bad v-fan? I wouldn't think the tstat since it made it the whole drive without running hot. I should also note it was pretty cool this morning, probly around 60F.
Details...
94 D-90 V8
Replaced tstat and water pump maybe 3 yrs ago
Runs warm from time to time, usually when its hot out and I'm sitting in traffic, then cools as I get moving again.
Old October 19th, 2012, 09:52 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Try to follow leak, may be just a bad hose. See if hoses at under pressure and firm when truck running & hot.... where's the leak? I had a leak few yrs ago, pooling in valley space, thought the worst & was just a bad hose.... became good opportunity to replace all of them.....
Details...
94 D-90 V8
Old October 19th, 2012, 05:18 PM
Pressure test the system ... That will find the leak. Borrow a pressure tester from autozone.
Old October 19th, 2012, 05:26 PM
It is leaking. Top it up now, figure out what is leaking (hose, waterpump, valley gasket end seals, head gaskets etc.) and fix and you should be fine. Don't drive it without topping it up first.
Old October 19th, 2012, 05:55 PM
In order of magnitude:
Loose hose clamp
Blown hose
Blown gasket on thermostat housing, or some other handy place
leaking water pump
Leaking radiator
Blown head gasket
cracked block/head/slipped liner
On the bright side, if it was OK yesterday and pouring coolant today, then it would probably be a hose. The other ones take time to develop....except for the cracked block but that's usually the result of an overnight hard freeze.
Old October 19th, 2012, 07:02 PM
tdn's Avatar
tdn
Troy Norton
'94 D90
Well I topped it off and drove it home. Exact same issues, starting running hot as soon as I was off the hwy in stop-go traffic. Opened the hood and this time found coolant leaking from somewhere behind the water pump. Wasn't coming out front of pump by belt so I think the pumps ok. Maybe a hose or tstat housing gasket or something. Cooling off right now I will dig in a little more in the morning. Hope I didn't cause any damage running it hot. The needle was just under the red zone for a few minutes. Truck was still running fine except for higher idle than usual. Thanks for the pointers
Old October 19th, 2012, 08:36 PM
2 awkward hoses behind the pump ... One rubs on a clip an wears a small hole. Swap them both.
Old November 20th, 2012, 05:51 PM
tdn's Avatar
tdn
Troy Norton
'94 D90
Just wanted to follow up....leastonce hit the nail on the head. bad hoses, swapped them out and problem fixed. on a side note, I just got a code 14 - coolant thermistor. I'm guessing its either bad or loose connection. saw some other posts on this subject, just wondering if anyone has a part number??
Old November 20th, 2012, 06:23 PM
http://www.roverparts.com/Parts/ETC8496.cfm
coolant
300 TDi blowing coolant out of overflow bottle cdb Defender Technical Discussions 16 April 12th, 2011 04:22 PM
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Overflow tank issues Doug Defender Technical Discussions 5 September 15th, 2004 10:23 PM
Radiator reservior overflow Neo Defender Technical Discussions 1 February 27th, 2004 11:51 PM
