Coolant loss ? keep an eye under the pump - Defender Source
Old November 11th, 2014, 04:01 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I was losing about a quarter of coolant, nothing on the floor, hoses are tight, head gasket is recent then I noticed the coolant pump has a small, about 1/8", hole under the housing of the shaft and it was leaking boiling coolant on top of the PS pump, bracket, hoses, etc.
If I remember well it was the factory pump, 9 years old and 90,000 km, so i'm not going to complain, some cleaning time and a new airtex.
Cheers
- Charles Eames
Old November 11th, 2014, 04:31 PM
ezzzzzzz
Mark Garrenton
That's the factory weep hole to indicate a failed internal seal on the pump shaft.
Old November 11th, 2014, 04:43 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I wonder if it could be routed somewhere down to avoid this:
- Charles Eames
coolant
hot cocoa on the ground- instantaneous loss of coolant delosanasazi Defender Technical Discussions 5 September 13th, 2014 10:39 AM
Mystery Coolant Loss - 200TDI Howski Defender Technical Discussions 15 May 31st, 2013 10:59 PM
Oil Cooler on D90- To keep or not to keep - that is the question! flananuts Defender Technical Discussions 10 April 25th, 2012 11:24 PM
NE members keep an eye out for this phoenix37 Misc. Chit-Chat 24 November 29th, 2011 04:41 PM
Replace fuel pump or keep original?? 94 D-90. redrockrover Defender Technical Discussions 13 December 22nd, 2007 10:24 AM
