Coolant leaking into cylinder mystery - Defender Source
Old April 16th, 2007, 03:58 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I've got coolant leaking into one of the cylinders on the driver's side. The coolant superheats and boils off & then the engine overheats. I thought this was simply a blown head gasket, I had it replaced last year, but now I'm somewhat at a loss to explain it.
Process so far:
The head was checked tested by a machine shop and it came back OK. Asumed blown head gasket - replaced and reassembled - the leak is still there.
Sent head back to machine shop to see if they missed something - they did not pressure test (visual only for cracks). Pressure tested OK.
Reassembled, new head gasket, the leak is still there.
I've had a guy out to check the block for warpage. He said it's good.
Reassembled, new head gasket again.
Still getting coolant in cylinder.
Sent head to a different machine shop, they also said it's OK.
Cylinder looks good visually - the sleeve has no visible signs of there being a crack or hole in it.
Any thoughts?? Could there be a leak up in the intake manifold that would only result in coolant in one cylinder?
Old April 16th, 2007, 12:38 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Another datapoint - when I got the truck two years ago there was a little coolant stain on this same side of the engine originating near the head gasket. I had the gaskets replaced & the heads re-done and the truck was OK in this respect until recently.
Is it feasible that the head is cracked and only leaks when it's hot so it's not getting marked bad during the pressure test the machine shop is doing?
Running out of ideas short of replacing *major* components, which is an expensive way to troubleshoot. I am not sure replacing the block is my cheapest option - so all things being equal I tend to blame the head (as my least painful option???).
Old April 16th, 2007, 12:41 PM
Andrew Vick
Andrew Vick
95 D90
Slipped liner, I would think.
Old April 16th, 2007, 01:55 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
What would be the evidence of a slipped liner? Can that be repaired in-car? Ugh...
Old April 16th, 2007, 02:08 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
If it is a slipped liner, you need a new block. Swing by my place and check out this 4.0 I"m assembling, I'll show you how a liner can slip.
Neil
Robert Deniro
Old April 16th, 2007, 05:38 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Are you around tonight? I have to be in Pasadena at about 8-8:30pm. Let me know, I could stop by earlier - 310.408.2399 or email directions jaherring@usa.net.
Old April 17th, 2007, 07:50 AM
Andrew Vick
Andrew Vick
95 D90
Sorry to suggest that and not give you any backup. I'm just going from experience, and it points to that. If you can run by Neil's, I'm sure he'll make it clear. Good luck.
Old April 17th, 2007, 08:59 AM
Cirbo's Avatar
Cirbo
Jim C.
Symptoms sound like a slipped liner. I had that fun with a 4.6, but didn't think it was as common on a 3.9.
Good luck.
Old April 17th, 2007, 06:47 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I was reading on ECR's website that you shouldn't be using the bottom four head bolts on "older" rover engines or it can cause the head gasket to leak - does this mean any engine with a 14-bolt head? I the newer ones are 10-bolt, correct?
Old April 17th, 2007, 07:55 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
That's correct, it applies to all the 14 bolt heads. The 10 bolt heads resulted from Rover removing the offending 4 bolts. However, it is recommended that if you have a 14 bolt head to still have the bolts in place, just torque them much lighter than normal, 25lbs is all I did mine at. This way you don't collect anything in the holes.
My oil line fix
My 100k stopped odometer fix
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
