Coolant Leak - Help! - Defender Source
Old March 14th, 2006, 10:32 AM
mlw911
Michael Walter
1995 D90 ST
Hello all. Just had my heads redone and now have coolant leaking between the back of the cylinder block and the transmission from that little 1/2" drain hole on the bottom of the housing. I have learned now that the head gaskets may have not been the culprit after of course having them redone.
Question is now that we know there is not a leak from the gaskets, what else could be leaking colant down the back of the block and what is the best route to take. Mechanic says pull the trans as its the freeze plugs or a bad engine block. Uuuuugh!
Old March 14th, 2006, 01:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yeah, freeze plugs are a very good possibility, there are two of them on the backside of the block. Unfortunately the only way to get to them is to pull the tranny or engine, since they are behind the flywheel. There is no way to even see them otherwise.... probably the most expensive $3 part in the whole truck.
While you're getting it done, if you are still on the original clutch and if your mileage is over 50k or so, might as well put a new one in if you can afford it. Save a lot of labor cost down the road, since they have to take the old one off anyways.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 15th, 2006, 07:56 AM
mlw911
Michael Walter
1995 D90 ST
Thanks Hans! More people have had to run into a similar situation. Help!!!!
Any ideas on what it costs to drop a tranny?
Old March 15th, 2006, 08:28 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
a good mechanic will have it out and back in in 10hrs at the most.
3rd low and BOOT IT
Old March 15th, 2006, 08:35 AM
Eric_S
Eric
'97 D-90 ST #1507
I had a coolant leak that looked like it was coming from the back of the engine but it turned out to be leaking at the thermostat housing. The coolant was running down the top of the engine between the intake and block (not sure if a '95 has a raised intake like a '97) then running down the back of the block. Before you drop the tranny check all the hoses and thermostat housing.
Eric
Old March 15th, 2006, 10:58 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Sounds about right. I was quoted 9.5 hours labor to do my clutch. I decided to do it myself in the driveway with the help of a friend you all know. I think it can be done in about 4-5 hours with a friend if you know what you're doing. There's your 9-10 hours labor.
Pics of the fun below.
ID:	5222   Click image for larger version
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old March 15th, 2006, 11:08 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
My shirt still looks like that after 3 washes. Think the old Rovergirl long sleeve has reached its presentation end.
Chris von C
[/size]
coolant
300tdi Coolant Leak Lee Defender Technical Discussions 10 April 22nd, 2009 10:46 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
