coolant leak, but where's the source? - Defender Source
Old July 21st, 2007, 04:16 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
After having to top up the coolant in the expansion tank for the second time, I noticed two puddles of standing water under the hood. The ground is dry, and the rest of the engine bay is also bone dry including the area around the expansion tank. No overheating issues.
the water pump is 10 months and 3000 miles old. One of the screws that holds the water pump to the housing and the alternator tensioner broke. Do you think that is related, and if so, what size is that bolt supposed to be? That was a replacement one after losing the first one, but it keeps working its way out of the water pump housing I guess.
File too large, so I am going to take some smaller pics of the puddles...
BTW, this is the RRC
ID:	9848   Click image for larger version
Old July 21st, 2007, 04:31 PM
hows the valley pan/intake manifold gasket? THat would be my guess based.
Old July 21st, 2007, 04:54 PM
Gore Ranger
Jeff
1989 RRC
the entire motor was professionally resealed by the 4x4 center in
VT 3 years ago (10K miles at most)
Old July 21st, 2007, 05:22 PM
Andrew Vick
Andrew Vick
95 D90
In the first picture, it looks like there's a short hose, just above the cap and wire (would be to the back). In a 95 Disco I had, that short hose had a pinhole leak that would spray coolant right where your picture shows. Never figured it out until the hole got bigger.
Good luck.
Old July 21st, 2007, 07:25 PM
Gore Ranger
Jeff
1989 RRC
hmmm. interesting. After I get the water pump bolt locked down with the correct piece, I am going to dry everything off and idle it up to temp with the hood open and see if I can see anything squirting.
OK, I am 99% confident that it is that little hose upon further investigation. Thanks Andrew
Old July 21st, 2007, 09:01 PM
Andrew Vick
Andrew Vick
95 D90
You bet. An close match will work short term, but the factory hose is smaller at one end, or larger at the other, depending how you look at it
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
