Coolant Leak Also - Defender Source
Old January 7th, 2008, 08:37 PM
matthewwcarey's Avatar
matthewwcarey
Matthew Carey
95 D90 SW349
Coolant Leak Also
I'm losing coolant also, but it's collecting on the floor and only for about an hour after shut down. It's dripping off the lower belt, but I think it's coming from the water pump above?
Old January 7th, 2008, 10:03 PM
Grover's Avatar
Grover
There is a small weap hole behind the water pump pulley that will start to leak when the pump is on its way out...also, check all hose connections...
Good luck...
Old January 7th, 2008, 10:04 PM
matthewwcarey
Matthew Carey
95 D90 SW349
Thanks for the help.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
