Coolant leak? - Defender Source
Old November 2nd, 2006, 09:46 PM
tmore
Tom More
1995 D90
Coolant leak?
95 d-90 with 300tdi...
Over the last two days I have noticed what smells like a strong coolant smell while driving. When I am parked in my garage I can still smell it but not nearly as strong. I am not seeing any leaks inside or out, I have left a piece of cardboard under the vehicle and inside on the floor and have not seen anything. The coolant level appears to be at the right level.
Any suggestions?
Old November 2nd, 2006, 10:05 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Is the smell coming from inside the vehicle or outside? Are you running heat?
I don't know squat about specifics of the TDI, but have had similar issue where the pressure from heat (PV=nRT) put off into the coolant will push a small trace of coolant that boils off. Ocasionally so small of a trickle it never drips on the ground, especially if it has to run across a hot engine surface so it ends up just boiling off. I would poke around and sniff around and look for somewhere shiny, in particular around hose fittings/end and mating surfaces. If you are smelling it inside, perhaps the heater core is leaking slightly. Just my 2 pennies.
Pain is weakness leaving the body
Old November 3rd, 2006, 12:31 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Just to echo what Jeff said, (along with owning a V8) I had a smell of coolant too. No drips, puddles, etc. The telltale was when I would put it to defrost, it would fog up even more. I went for the heater core. After it was replaced, problem fixed. I believe the heater assembly is the same for both engine types. Word of advice if you do go for the core, don't buy the part from Atlantic British. I don't think it's LR Genuine (Britpart?) and required really boogering up the heater box assembly to fit it (cutting, grinding, repainting) and the inlet/outlet hose fitings were so close together that I had to soap up the coolant hoses to fit them. This time it would pay to go Genuine.
Once I got the assembly out I expected to see a leak trail or something...not a thing. Even inside the assembly on the core, not a trace.
Good luck.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
