Coolant Leak - Defender Source
Old February 7th, 2015, 01:11 AM
RBBailey
RBBailey
1965 IIa
Coolant Leak
Went out to start the 110 (3.5l) today, and noticed a small pool of coolant on the ground under the drivers side behind the bumper.
Didn't get a chance to do anything with it yet, except to wash away the coolant so as to keep the cats from licking it.
This will be the first time I'm looking into a problem under the bonnet on a Defender. Other than the standard cracked hoses and welds, is there anything I should know about and look for?
...time.... need... more.... time......
Old February 7th, 2015, 10:22 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Check all your hose clamps first. Several times I've seen coolant I've found it to be a hose clamp .
Old February 7th, 2015, 02:09 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
And don't just check above the pool-- it can travel away from the leak. Lots of possibilities including blowing out overflow hose on reservoir, weep hole on water pump, and cracked radiator. Hope it is a hose, as that is easiest...
Old February 7th, 2015, 02:24 PM
RBBailey
RBBailey
1965 IIa
yeah... now I don't see anything leaking except a bit from the bleed screw. But the pool of coolant I saw was right under the LH radiator. Now I have the truck in the garage, and it isn't leaking anyplace.
NOTE: The puddle formed there after I had the vehicle parked for five days. I've never noticed any leaks before this, warm, cold or otherwise.
Old February 13th, 2015, 07:09 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Pressure test the cooling system, tester can be purchased at Napa/ auto parts store. Just don't take pressure over the rating on the pressure cap. Usually 15psi. Once pressurized let sit for a few hours and look for leak.
Old February 13th, 2015, 07:17 PM
Clamps would be first suspect. When winter hits and temps drop i usually get a few drips here and there around clamps and hoses that were put on fresh in warmer weather. Cold makes the rubber shrink a bit thereby creating some slack under the clamp. Get it tight in winter and it should stay that way until you loosen it again down the road for something.
Its the coolant loss that you cant find puddles or leakage for that keep me up at night. When i see a dribble of coolant I thank God for that blessing.
Mark Kellgren
KM4BOR
Old February 13th, 2015, 07:26 PM
I just went through this. As others stated above, once the cold hit I started to get a couple of small puddles. The hose clamps had backed off or the hoses contracted. Found the offending hose, tightened the hell out of the clamp, and I've been puddle free for a month.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
