Coolant Leak - Defender Source
Old September 16th, 2013, 05:04 PM
K9Phil
Phil
1994 D-90 #1184
Coolant Leak
I noticed a small wet spot on the garage floor over the weekend directly under the front bumper (driver side). Upon closer look it is dripping from the underside of the frame horn, but I couldn't find the source. I ran it by a couple of local mechanics who have both done some work on it and they both said it's probably coming from the bottom corner of the radiator. The lower hose is on the other side and all hoses look to be dry and not leaking.
So, two questions...
1) Anyone disagree or have any other thoughts?
2) If these guys are right, am I better off getting this one repaired, or am I looking at dropping in a new radiator?
Old September 16th, 2013, 05:49 PM
Pressure test it to be sure, the radiator is an expensive item to replace.
Old September 16th, 2013, 05:54 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Can be a hose, a hose clamp, radiator, etc...
You should give it a good cleaning and check it daily with a flashlight to see where it's coming from.
- Charles Eames
X2 on pressure test. You can also have the existing radiator re-cored which saves a few bucks over a genuine rad.
Old September 16th, 2013, 05:56 PM
Originally Posted by K9Phil View Post
I noticed a small wet spot on the garage floor over the weekend directly under the front bumper (driver side). Next to deposits of power steering fluid, engine oil, brake fluid, gear and transmission fluid ...
Fixed it for you ...
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
