coolant leak - Defender Source
Old February 26th, 2005, 04:16 PM
jperakis
James Perakis
94 ST
coolant leak
ok so i start the 90 up this morning no problem, get to the place i was going, and when i come back outside there is coolant pooring out of the truck. it was not commin directly from the radiator or any visible hose, but rather from right below the air intake maybe a little off to the left of it but essentially right there. you guys have any thoughts on whats goin on?
Old February 26th, 2005, 05:07 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Haven't experienced it myself, but sounds like that's the demon heater element or heater hose.
DW
You can cut a hose and bypass it, a lot of guys down south here just bypass and forget the heater core.
DW
Old February 27th, 2005, 02:39 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
He has a soft top. Even in So. Cal., you want the heater on a cold night in a convertible with the top down. 'used to do that in my girlfriend's (now wife) Alpha when we lived down there.
coolant
300tdi Coolant Leak Lee Defender Technical Discussions 10 April 22nd, 2009 10:46 PM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
