Coolant issues - Defender Source
Old May 13th, 2013, 07:48 PM
Gummernaut
Gummy
1995/D90
Coolant issues
My 1995 D90 has had coolant spitting out of the reserve for a while now. So I had the radiator flushed and checked. Still happens. Next put on a new cap since the previous one was an aftermarket one and 16lbs. Still happens but not as much comes out. Any suggestions?
Old May 13th, 2013, 08:12 PM
Head gasket over pressurizing the system. Pull you spark plugs and look for a steam cleaned one.
Old May 13th, 2013, 08:32 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yep. You can also get a bock tester at Napa-- do a search, I've listed the number before. Sometimes, as with mine, I couldn't tell from my spark plug alone. Start with the plugs-- it's free to check those, but if it is undetermined, them I'd get a block tester. It is like a giant test tube that you pull air from your reservoir through-- if fluid changes color, you have issues. Mine turned out to be a slipped liner....
Old May 13th, 2013, 10:06 PM
Gummernaut
Gummy
1995/D90
Thanks for the advise. I'll call NAPA tomorrow.
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
