Coolant hose to intake diameter - Defender Source
Old October 11th, 2013, 12:28 PM
What's the inner diameter of the coolant hose that goes from the valley pan to the intake/plenum? The closest I could find at advance auto was 7/16th fuel line and it's a bit too big for comfort.
Originally Posted by pendy
I'm here for the D's
Old October 11th, 2013, 04:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
On the 4.6 it's 8 mm or 5/16" if I remember well.
- Charles Eames
Old October 11th, 2013, 04:57 PM
Thanks Julien
coolant
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
air intake hose --molded or flex jack SF Defender Technical Discussions 3 September 24th, 2010 12:30 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
