Coolant hose leak - cure in a can question - Defender Source
Old May 21st, 2005, 10:55 PM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
Anyone have a strong opinions about those liquids you add to your coolant to seal the leaking hoses?
I have a spot that seems to leak coolant like a geyser and I can't seem to get it to stop.
I have been told (by one shop) that there is "no cure in a can!"
I am not sure if this is their way of getting me to pay them rather than poor a can of stuff in and solving my problem.
I appreciate the help
michael15@mindspring.com
95 D-90
Old May 21st, 2005, 10:59 PM
Buy a new hose, what are you thinking???
Old May 21st, 2005, 11:33 PM
Oh god dont use that leak stop stuff. It crystalizes in there and makes a mess. I had an old car where some PO did that to stop a leak in the heater core. It gave way after I took ownership and there was this awful crystalized mess inside my heater valve, heater core, and the rest of the cooling system. So I had the pleasure of having everything hot tanked and cleaned.
If you have leaks around a hose, replace it. Sometimes new hoses will leak until you get everything seated properly. The expensive as hell t-bolt hose clamps from McMaster will help a lot and look great doing it. They are part number 8946K series clamps on page 216 of the catalog - available in all stainless. www.mcmaster.com
Old May 21st, 2005, 11:36 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
A lot of coolant leaks at hose connections is really just too loose a hose clamp. However, there are two other contributing factors and those being old brittle hoses and corrosion at the hose nipple (ooohh, he said "nipple!"). I always take some sand paper to those corroded nipples (ooooh) and make them smooth again...there are some leaks that can be cured with a "can", but I would not try that for a leaky hose. A lot of coolants add silica to stop leaks and that is really what I added recently to stop an exhaust leak (successfully so far). You can add a UV die to your coolant (and another one to oil) and then use a black light to spot exactly where the leak is.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
