Coolant Flow Path 2.5 NA Diesel - Defender Source
Old October 16th, 2011, 09:43 AM
edh
Ex mod 90
Ok , title says it all, what is the direction of coolant flow an a 2.5 na diesel? I don't have a repair manual and rather than disconnecting a hose from the heater and dumping a but load of coolant out, I thought I would ask here. Yes, I did a search on the world wide interweb.
Old October 31st, 2011, 10:26 AM
edh
Ex mod 90
Anyone?
I installed an espar d5 heater inline w/ the heater. It works fine w/ the truck running but throws an overheat error when used as a stand alone. After a quick chat w/ the nice people at Espar NA it was determined to be a problem w/ coolant flow, I blame the idiot that did the install. So I am trying to figure out the cause of lack of flow. I can feel the coolant moving through the heater just not sure why it does not seem to be flowing through the block.
Old October 31st, 2011, 11:03 AM
I'm assuming a 2.5NA would flow pretty much the same as a 300TDI. If so, I can post that diagram. If you put your espar inline with the heater, did you make sure to have your heat controller on the dash set to hot to open the flow? (had to ask). I'm thinking it's also possible that you have a lot of air in the system from the install.
I have a webasto installed, so I'm sure together we can solve this.
http://www.landyzone.co.uk/lz/attach...oling_flow.jpg
Old October 31st, 2011, 11:31 AM
edh
Ex mod 90
Mark,
Thanks for the reply,& the diagram of the 300tdi. It does look different than the NA though. The return from the heater looks like it goes to the top of the thermostat/ water pump.
I will try bleeding the heater again.
Is there a valve to control coolant flow on this engine? I thought that it was full flow all the time. The heater control cables seem to control flaps in the heater box itself.
Old October 31st, 2011, 11:51 AM
To be honest, I have heard and read claims for both constant flow and blocked flow on that temp control. I have never disassembled one to confirm either way and would love to hear someone with hands on experience state one way or the other.
As for you issue, another possible cause might be that your integral coolant pump on your espar isn't moving, and so that static flow in the heater overheats at the point where the espar is measuring it.
Old October 31st, 2011, 04:00 PM
edh
Ex mod 90
Thanks again, I can feel movement in the hoses to and from the heater.
I actually just removed my heater to enlarge the bulkhead hole and there were 2 cables that seemed to only operate flaps. I also had a bad fan switch and that cable definately operated the flap ,bulkhead iirc.
I will try to run the heater w/ the ignition in the on position w/ engine off to see if there is a control valve that requires the truck's heat to be turned on.
Old October 31st, 2011, 09:17 PM
The inside line is the line to the heater. Outside is the return. There is no valve in a Defender heating system.
------ Follow up post added October 31st, 2011 07:23 PM ------
Here is a photo of a 2.5TD (same engine): http://lib.store.yahoo.net/lib/yhst-...10engine1.jpeg
Line on left is return to pump suction/bypass line
Line on right is heater supply from head.
Old November 1st, 2011, 12:46 PM
edh
Ex mod 90
John,
Thanks that is similar to my 90 except lhd.
I have the espar plumbed into the heater hoses from the head out to the suction in.
Is there a way to make this set up work?
Is there a more ideal location to plumb the Espar?
Old November 1st, 2011, 02:30 PM
sounds perfect to me as is.
Old November 1st, 2011, 04:25 PM
Yes, between the engine and heater on the line to the heater is the best place especially if you wish for it to help the heater while driving.
Old September 14th, 2013, 08:22 AM
scrubs
henery
1974
So how did this workout? going to try this today
coolant, diesel
2.5 NA diesel motor “kit” 87K documented miles dave_lucas For Sale - Parts 3 January 15th, 2010 09:27 AM
Where to buy 2.5 NA diesel weld in motor mounts? dave_lucas Defender Technical Discussions 15 July 26th, 2009 10:18 PM
91 Ex-Mod D-90, 2.5 diesel for sale DaveG For Sale - Vehicles 10 February 7th, 2006 01:10 PM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
