Coolant and temp gauge - Page 2 - Defender Source
Old August 16th, 2016, 12:22 PM
Originally Posted by Michael699 View Post
Will the factory sender work with VDO gauge?
Nope.
Old August 16th, 2016, 12:41 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Check the pitch of the threads on the stock sender. Depending on your application they could be fine or coarse. I mention this as I just switched over to a VDO sender and the adapter that came in the kit didn't fit.
Old August 23rd, 2016, 11:14 AM
Michael699
Michael
1985 110 2.5 Diesel
So which kit should I buy for the Gauge and Sender combo? 1 or 2? which will have the correct adapter?
------ Follow up post added August 23rd, 2016 11:15 AM ------
Sorry Eat High I didn't see your reply. to me to they look "Fine".
Old August 23rd, 2016, 11:29 AM
The 2.5NA use two different size sender threads. You need to pull the one on your engine to see what you have.
coolant
FS Oil or Coolant Temp Gauge in C rdavisinva For Sale - Parts 9 October 10th, 2016 08:47 PM
OEM fuel gauge, water temp gauge and tach defender1844 For Sale - Parts 4 June 27th, 2016 12:45 AM
FS: Clock and Temp Gauge spartan For Sale - Parts 10 August 28th, 2013 06:51 AM
110 Oil Light and temp gauge bjf Defender Technical Discussions 25 May 26th, 2009 08:45 PM
Need tech specs on vdo temp sensor and gauge airbornrover Defender Technical Discussions 0 May 23rd, 2009 10:24 PM
