Cool Runnings - Defender Source
Old January 27th, 2013, 12:16 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Cool Runnings
Got a problem with heat, or lack there of, in my 110. Engine is a 300Tdi. I noticed over the last couple months the temp gauge has been reading lower and lower. Now is barely rises off the cold mark and there is next to no heat from the heater. Coolant level is fine. WTF? It has been fine in past winters temp and heat wise. Only thing I can figure is maybe the thermostat is sticking in the open position. Would this cause over cooling? Makes the morning commute in -20c a chilly affair. I have noticed that if I have the block heater plugged in for a couple hours, the temp gauge actually comes up a little bit higher but not a lot of extra warm out of the heater.
Any other ideas or thoughts?
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old January 27th, 2013, 12:35 PM
Arran73's Avatar
Arran73
Arran Thomson
1987 90 soft top
Sounds like your thermostat is blocked open
Old January 27th, 2013, 01:49 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
is there a viscous fan coupling like on the v8's? could be stuck "on"..
Old January 27th, 2013, 05:15 PM
moose's Avatar
moose
Brett
Fan spins freely. There is some resistance but it is not seized or anything. Looks like I need to scare up a new thermostat. Hope somebody has them in stock.
Brett
Ex-Mod 110 Tdi
Old January 27th, 2013, 05:57 PM
Thermostat failed open. Some are designed to do that. No big deal.
Old January 27th, 2013, 08:58 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I didn't have any problem getting one from Rovers North when I replaced mine.
Old January 27th, 2013, 09:00 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Change thermostat. Block radiator with a muff or cardboard.
Old March 9th, 2013, 07:37 PM
Do you guys use a 74 or 82 degree thermostat on your diesel?
Old March 9th, 2013, 11:28 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Your problem is almost 100% assured a stuck open thermostat. 192 degrees is what you want. Other modern diesels out run as high as 205*F. I myself built a 198*F by combining 2 Mororad thermostats. Look up threads on "300tdi thermostat" on this forum.
------ Follow up post added March 9th, 2013 09:30 PM ------
Factory calls out 192*F
Old discus BBS--pretty cool! Rod Hayward Support & Suggestions 18 July 7th, 2009 11:44 AM
Cool Pic rustydefender Misc. Chit-Chat 12 December 6th, 2005 12:41 PM
Cool Truck TDI Guy Misc. Chit-Chat 13 May 27th, 2005 06:40 AM
cool site jabber Misc. Chit-Chat 5 April 4th, 2005 10:50 PM
Cool Video on wheeling Mike Hippert Misc. Chit-Chat 10 December 10th, 2004 06:51 PM
