Cooked my brakes - Defender Source
Old July 12th, 2015, 09:23 AM
toad's Avatar
toad
Cutter
Cooked my brakes
In the process of pulling one my front shock towers I inadvertently cooked a brake line freeing up a nut. I finished buttoning things up and when I backed out of my garage there was no brake pressure.
I'm thinking I'm going to crawl over to a shop around the corner and have them drain the system, but is there a chance I damaged anything? The brake line was pretty lit up, should it be replaced? In hindsight I should have used a shield.
Old July 12th, 2015, 09:33 AM
Put in a new line and flush the system.
Old July 12th, 2015, 09:46 AM
You probably just annealed it. However since your life depends on your brakes I would do as John recommends and replace it. They are cheap.
Old July 12th, 2015, 09:55 AM
What kind of brake line? Teflon/Ss, copper alloy?
Old July 12th, 2015, 10:00 AM
They should be easy to get a replacement made just check that there isn't a special flare on the ends.
Old July 12th, 2015, 10:02 AM
if you are talking about the hard line that passes behind the shock tower you likely boiled the fluid. My guess would be bleeding the brakes would cure the issue.
Old July 12th, 2015, 10:14 AM
toad's Avatar
toad
Cutter
Aye the hard line, not the flexible hose. Thanks all, I'll see if the shop can make up a replacement or order one.
brake
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Just cooked a birds nest on accident. Bryanfor311 Misc. Chit-Chat 1 May 2nd, 2012 02:04 PM
Harness sleeving cooked, cracked and falling aparts JFD Defender Technical Discussions 0 June 1st, 2011 06:38 PM
D-90 Brakes scot Defender Technical Discussions 20 April 23rd, 2009 12:17 PM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
