Converting a NAS D90 soft top to hard top - Defender Source
Old October 16th, 2015, 02:21 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Is this possible? What parts are required, and are they available here in the US?
Thanks for any and all info.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old October 16th, 2015, 07:30 AM
http://www.defendersource.com/forum/...-sw-11092.html
Old October 16th, 2015, 07:31 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Yes it's possible, are you looking for permanent or for winter conversions. There is a reason I am asking...
Old October 16th, 2015, 09:33 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Permanent conversion.
Thank you - Samer
2003 Discovery II
Old October 16th, 2015, 09:47 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Why make the conversion? There are more 90 SWs than 90 STs. This makes SWs cheaper to come by and more readily available.
If making the conversion, Brian would be a good person to perform the switch (and licking his chops to get his hands on that cage for $$ 110 ST conversions....).
Old October 16th, 2015, 09:49 AM
jafir's Avatar
jafir
Jafir Elkurd
It's your vehicle, so obviously you should do what you want, but I believe the consensus is that the soft top NAS 90 is worth more than the station wagon. I would look for the fiberglass hardtop that goes over the ST cage, and just leave on as if it's permanent. That way if you ever do decide to sell it, it's still a ST. I think people have tried to sell NAS ST cages for $5000 or even more because they are hard to get (NLA new) and desirable.
Or if you do a full SW conversion, at least keep all of the ST parts, because you'll probably never find them again if you want to swap back.
Just my $0.02, and I'm no expert because I've never owned a NAS 90.
Old October 16th, 2015, 09:54 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Jafir: good to know, thanks for the info.
Thank you - Samer
2003 Discovery II
Old October 16th, 2015, 10:22 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
It sounds like a winter conversion is more in order, "cheaper" to do, and allows one to keep all the ST parts on, especially the cage. The truck is in Southern California, any recommendations on a shop that can do this? I don't have the time or inclination to undertake this work.
Thank you - Samer
2003 Discovery II
Old October 16th, 2015, 10:29 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
What is the winter conversion you speak of?
Considering how much space the cage takes up to store, i would just put a fume curtain on the B pillar, so that the cab is partitioned from the load area, which is way less space to heat. Installing a fume curtain is easy, and they are cheap (~$200), especially when compared to buying a hard top and paying someone to convert.
Old October 16th, 2015, 10:32 AM
I'm still confused why a hard top is necessary?
Old October 16th, 2015, 10:59 AM
defender1844
Amit Likhyani
something I'm going to do but way down the line is the following:
1. get a fiberglass top from d90tops.com. It's difficult to get OEM fiberglass hard tops in decent shape and the d90top has some additional support and superior materials.
2. Get a set of powered SW doors with hinges. When I want to go into hard top mode, it's 4 bolts, disconnecting a check guide and unplugging a harness to swap from the ST doors to the SW doors.
In Austin I'm 8 months no roof, 4 months with a roof. There is no way I'd do a permanent conversion.
Old October 16th, 2015, 12:30 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
John,
This "winter conversion" sounds like a non-permanent solution to my original question. Almost like a hard top option on a convertible car.
The intent of my conversion initially was for a permanent solution, but it sounds like, from the various recommendations here, that the better option is to keep the ST cage and install a fiberglass roof, rather than do a "permanent" swap of parts. I'm in SoCal, so colder winter temperatures are not really an issue here, and are not the reason behind this conversion, it's rather wanting an SW truck as opposed to an ST.
It sounds crazy, I know, why not buy a SW instead of an ST from the get go, unfortunately, it's a little too late for that.
Thank you - Samer
2003 Discovery II
Old October 16th, 2015, 12:32 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
hold on there...
Now just wait a minute , just wait a minute......
I'm having difficulty deciphering LRFAQ, but can anyone give me the definitive answer as for all 3 years of 90's. The number of Soft tops vs hardtops?
Just curious....I know that there were 188 1995 Coniston Green Station Wagons...
Which by the way makes them more rare than the Willow Green 97 LE.
Just saying'..
Attributed to Shayne...
Old October 16th, 2015, 12:33 PM
jafir's Avatar
jafir
Jafir Elkurd
If your Defender is in pretty decent shape, another option might be buying a SW and selling the ST, and pocketing the difference.... of course then you are going from the a vehicle you know to one you don't, but I assume if you get it inspected by someone that knows what to look for, you could come out ahead.
Old October 16th, 2015, 01:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
What year/color soft top do you have?
Old October 16th, 2015, 01:56 PM
down_shift's Avatar
down_shift
Russell
edit - thought that ^^ was Keith
Old October 17th, 2015, 01:36 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Brewie, check your PM.
Thank you - Samer
2003 Discovery II
Old January 12th, 2017, 03:53 PM
RomanCM's Avatar
RomanCM
Roman
94/D90
1995 Land Rover Defender 90 station wagon | Copley Motorcars
This is a permanent convesion that was done if you want detailed photos I can send them to you to give you a little flavor into what it could be like.
Old January 12th, 2017, 03:57 PM
phoenix37's Avatar
phoenix37
john
Drove by as Stu was taking the pics of that one over the holidays.. You might want to "un" convert that one
Old January 12th, 2017, 03:59 PM
RomanCM's Avatar
RomanCM
Roman
94/D90
THen it will just be another yellow soft top...to much time and money someone will like this build itsa cool truck the cage in the back is pretty cool too. We sold it originally as a soft top
90, d90, hard top, nas, soft top, top
Converting an 80's 110 to a soft top? johncunningham Misc. Chit-Chat 16 April 7th, 2012 06:58 PM
converting an old soft top to a surrey top Rufus Defender Technical Discussions 10 July 29th, 2010 11:01 AM
Converting a soft top to factory hard top? Daringer Defender Technical Discussions 27 February 19th, 2009 07:24 PM
converting a NAS 90 to a 110 jimmy salmon Misc. Chit-Chat 32 November 22nd, 2006 03:07 PM
converting to a hard top? ALPHAMALE Defender Technical Discussions 23 October 2nd, 2005 12:29 AM
