Converted 300 Tdi with gas fuel filter still - Page 2 - Defender Source
Old October 26th, 2015, 12:04 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by rdavisinva View Post
You have to be lucky enough to have always used a gas filter with composite media and not the paper style that will greatly restrict the flow of diesel.
With 2 filters, how do you know which one to change?
I always assume it's the gas filter since it's 1st in line in the filtering process. As far as the brand of gas filter, I just use Fram.
Old October 26th, 2015, 12:06 PM
mdcoa's Avatar
mdcoa
Bill
1995 Discovery
Related thread on proper 300TDi filtration/sedimentation, started recently by yrs. truly: http://www.defendersource.com/forum/...tor-64050.html
I had a setup similar to the one you're currently running, except it really was a gasoline filter, and . . . the lift pump had been connected by mistake to the return line, so my fuel was running backwards through the wrong filter on its way back to the tank . . . suboptimal.
I used one of Mr. Davis' sedimenters and am quite pleased with the result.
Old October 26th, 2015, 12:12 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My D90 is stock gearing, 31.5" BFG AT/KO's, 235/85-16's, the correct Zf auto for diesels and a 1.2 TC. No lift.
I consistently get 22-23 mpg at 4500' elevation. I do have a Detroit in the rear. I do have a Front Runner Slimline roof rack W/ my spare tire on it. IF I pull my tent trail, mpg drops to 19. I typically drive 62-65 mph turning 2200-2300 rpm's.
My conversion kit was of all new components in July 2001. I've turned down my fuel screw 1/8 of a turn because of my elevation. I NEVER see smoke, and on the dyno Opacity test it emits 2.5 to 5 % smoke.
Old October 26th, 2015, 05:17 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
I think I was maybe seeing around 21-22 in town. Best I ever got was the day I picked it up from Doug and drove home. Had a beautiful tailwind. I filled up in Baker City and had gotten a little over 26. But never got that kind of mileage again.
I would say with the lift, bigger tires, armor, equipment, etc that 19 is pretty good.
300 tdi, fuel, gas, tdi
99 hummer h1. Duramax converted with allison tranny NJT For Sale - Vehicles 5 November 2nd, 2014 03:31 PM
4.6 converted to distributor & ZF trans ocrover For Sale - Parts 15 April 30th, 2014 09:12 AM
1997 D90 LE 112/300 - Converted to Soft Top rijosho The Flea Market 18 September 3rd, 2013 11:10 PM
1994 ST converted to SW - anyone know this? brettm Misc. Chit-Chat 6 August 9th, 2012 05:20 AM
300 tdi fuel filter trybul Defender Technical Discussions 11 May 22nd, 2011 10:33 PM
