Contura Switch 3 way and 2 way - Page 2 - Defender Source
Old January 25th, 2009, 12:40 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Pics are always nice to see !
Thanks !
Pat
Kirk Lazarus, Tropic Thunder
Old January 26th, 2009, 11:45 PM
nimbusnic's Avatar
nimbusnic
nimbusnic
Classic Saudi Arabian 110
Pics!
From the left to the right next to the steering column:
Carling green-lit toggle for dash light.
Dome Light SPST
Electric Fan Override (works with temp sensor and AC clutch) SPST
Hazard switch (splices into wiring harness of original lucas switch) DPST with in-line diodes
I also posted a pic of my custom gauge/switch box attached to the front of the Tuffy. This box is holding a VDO voltage gauge, carling switches for my LED lights in the cargo area and aux lights for the roof rack (if I ever get around to installing them), and also holds a bussman fuse block. The box was fabricated for me by Len at American Dirt Roads. He also makes a dash/map light which I have installed in the dash behind the shifter. I highly recommend his stuff, and he is good about working with you on custom jobs.
If anyone has a tip on where I can find a green hazard contura rocker, it would be greatly appreciated.
Pat, where did you find your green rockers with the two lights facing down? Do you have the model number for this rocker?
ID:	17505   Click image for larger version
switch
