control arm 3link - Defender Source
Old November 5th, 2005, 09:06 PM
redrover
Guest
Posts: n/a
control arm 3link
I am going to put a new center link on the 3link. I have these beefy joints but not enough room at the axle mounting side. Does anyone know if I would be running into any issues if I made a new mounting bracket that extended another inch rearward? JP
Name:	control arms 005.jpg
ID:	4225   Click image for larger version
Name:	control arms 006.jpg
Old November 5th, 2005, 09:58 PM
no idea but that is a BEEFY joint!
Old November 5th, 2005, 10:39 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have not seen a joint that big since Cheech and Chong!
Pittman arm removal? dameek Defender Technical Discussions 20 October 12th, 2009 07:17 AM
99 RR Body Control Module chrisvonc Wanted 0 March 24th, 2006 11:16 AM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
