Continous Knock Fault - Defender Source
Old October 15th, 2004, 06:03 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
Yes...I used search. Borrowed a fault code reader. Searched again. Checked my plug wires. Searched again. Didn't see an answer to this question.
I have a whole slew of fault codes:
1) Continous knock fault Bank A
2) Misfire multiple cylinders
3) Misfire on #4
4) Misfire on #3
Like I said I checked the plug wires. I am going to pull the plugs tonight. What else should I be looking for? I am a novice mechanic at best so be kind.
Thanks in advance.
Boise, ID
Old October 15th, 2004, 10:14 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Adam,
based on the codes, your problem may be carbon buildup in the exhaust valve guides causing valve stick. There are updated guides and exhaust valves to sort out this problem. It's fairly common. The easiest way to manually check for valve stick is to pull the valve cover and rocker shafts, remove the suspected exhaust valve spring and manually move the valve...you can feel them stick.
Rob
Old September 10th, 2007, 01:03 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Careful how you do that - if the valve falls into the chamber, you have to pull the heads.
J. Robison has a good write-up in his site on how to check this.
Old September 10th, 2007, 04:00 PM
Is there some way that you can clean that out? Put in some sort of an addative or etc? I think my ST may be headed down that road and it only has 52K... I run premium but do not drive it everyday.
Old September 10th, 2007, 04:10 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Nope. That's why this exhaust valve issue is so imfamous.
Since these are exhaust and not intake valves, any addative gets burned up before it gets to the valve stem that would need to be cleaned.
Old September 10th, 2007, 08:28 PM
drive it like you stole it
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Rough Road Sensor?? scubadanster Defender Technical Discussions 25 April 19th, 2007 02:00 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Fault #P1317 Rob Defender Technical Discussions 2 October 29th, 2004 12:29 PM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
