Constantly confused by bolt materials - Defender Source
Old August 23rd, 2009, 11:31 AM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
Okay, I'll admit I have read so much mt head is spinning. What is the best bolt or screw material to use in aluminum? I just pur in some aluminum rivnuts and don;t know what type of bolts is best served. Stainless? Grade 10.9? Grade 12.9? (for screws) Grade 8? (for bolts) How do I minimize rust and/or corrosion? Thanks!
Old August 23rd, 2009, 12:45 PM
The best way to minimize corrosion is to use the same material. Technically, if you use stainless, you've made a battery and the aluminum will sacrifice electrons and corrode (did I say that right, someone correct me if I screwed up).
Anyway, the aluminum rivnut isn't very strong, so I assume this isn't a high-strength scenario. If you use a regular steel bolt with some anti-sieze, it will be good for a long time. Even stainless might be OK if you use thread sealant, anti-sieze, or just don't get it wet, but its less of a sure thing.
Old August 23rd, 2009, 01:08 PM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
I used them to put on wing top protectors; more easily removable when and/if I need to take them off. The aren't under and load in any particular direction. I used a grade 10.9, black steel bolt. It sounds like that is my best bet.
I used these:
http://www.mcmaster.com/#91294a238/=3bctmq
Old August 23rd, 2009, 01:34 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It really doesn't matter. The whole issue is overblown. If you still worrie about it, a small nylon washer will minimize contact.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 23rd, 2009, 04:56 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Galvanized is the best to use with aluminum as the anodic index of them isn't too much of a spread. That was the reason Land Rovers used mostly galvanized fasteners.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 24th, 2009, 10:08 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Why not use aluminum bolts and just use a couple more and perhaps a size up, it is not like a wingtop gets a lot of torque put on it and if you are putting a bead of silicone around that pretty much does all the grip you will need anyway.
Old August 24th, 2009, 10:46 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
For wing top plates just rivet them right to the wing, if you ever need to take them off (Why?) just drill the top of the rivets off.
Old August 24th, 2009, 12:10 PM
You are not permitted to speak on this matter as you live in California. For wingtop protectors, I would use plastic bolts like the license plate frame.
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
