Considering a move to Virginia, 300tdi registration question - Defender Source
Old December 6th, 2010, 08:28 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Pretty simple, I hope. Would I be able to register my '95 NAS D90, converted to a 300tdi, in VA if it's garaged in Louisa Co.?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 6th, 2010, 09:06 PM
I'll let someone with more knowledge chime in but I think you will be OK. VA is pretty easygoing on vehicle related issues.
Old December 6th, 2010, 10:45 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
general rule (as far as I've heard), if not arlington county or greater richmond area, its legal.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old December 6th, 2010, 11:10 PM
The Dro
Dro
1988 Ninety
You are fine. You have a pre OBDII year. In VA if the vehicle is 1997 or later you'll need to pass the emission test. Don't know why they did not include 1996.
------ Follow up post added December 6th, 2010 11:12 PM ------
found the webpage...
http://www.deq.state.va.us/mobile/mobfaq.html
Diesel-powered vehicles:
1997 and newer diesel vehicles with a manufacturer’s designated gross vehicle weight rating of 8,500 pounds or less will receive the on-board diagnostic computer system test. Diesel vehicles will not receive the tailpipe test, fuel cap pressure test, visual component inspection, or the visible smoke inspection.
The following vehicles require a Virginia Emissions Inspection PASS or WAIVER before DMV can complete the registration process. The requirements are categorized by fuel type:
Diesel-powered passenger or property carrying vehicles with a model year of 1997 or newer and with a manufacturer’s designated gross vehicle weight rating of 8,500 pounds or less
Old December 7th, 2010, 01:56 AM
You will have no problems in Louisa. Compared to Maryland, Virginia is a walk in the park.
Old December 7th, 2010, 07:14 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Thanks. I had found the DMV website, but wanted to make sure I was reading it correctly.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
300tdi, tdi, virginia
Converting to 300tdi - question re: R380 fitting jaherring Defender Technical Discussions 14 June 6th, 2010 12:33 PM
300tdi water pump question...doesn't look oem? nathanwind Defender Technical Discussions 16 May 22nd, 2010 04:34 PM
300Tdi AC question Gkase Defender Technical Discussions 8 September 13th, 2006 03:07 PM
question about installing 300Tdi kit from M&D? Gkase Defender Technical Discussions 12 May 24th, 2006 08:36 PM
