Connector for a 2-pin Speedo sender - Defender Source
Old April 21st, 2011, 08:48 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I though I had the right wiring connector for my speedo upgrade. Turns out the STC1188 does't work with a sender from a Disco. The pins on the sender are farther apart then on the STC1188. Any ideas where to get one that will work?
Old April 22nd, 2011, 08:10 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Are you using the Td5 harness or did you do away with that?
Land Rover 110
Old April 22nd, 2011, 12:24 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
The Lighting Adapter Harness you have (STC1188) uses a 2-way AMP Econoseal Connector.
The Speedo Transducer uses the 3-way AMP Econoseal Connector (but only uses the outer two pins).
You could use the Lighting Adapter Harness for the Stop/Tail Lights - STC1189 (superceded by AMR3334), but this costs a small fortune from Land Rover
A cheaper way would be to source just the connector, from a US supplier -
http://www.bmotorsports.com/shop/pro...oducts_id/1096
or, if you don't have the right tools to crimp the connector, they also sell a 'Pigtail' version -
http://www.bmotorsports.com/shop/pro...oducts_id/1677
I'm sure that there are plenty of other US suppliers for this connector, but Ballenger Motorsports are the only one I know of.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old April 22nd, 2011, 12:53 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
U can use a connector from a rear lamp like the turn sig plug
Legend in My Own Mind.
Old April 22nd, 2011, 01:14 PM
PaulMc's Avatar
PaulMc
Paul McConnell
That's what he already has (2-way connector) - The one he needs is the 3-way connector for the Stop/Tail lights.
Paul.
Old April 22nd, 2011, 01:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, that makes sense, I wish I had one of those laying around too.
As far away the TD5 HARNESS I am going to use it, if it is a td5 harness, I was confused when I took the engine harness apart and only found 4 glow plug leads?
Old April 22nd, 2011, 05:31 PM
Are you saying that the 3 way plug fits on the 2 prong VSS??? Sounds strange.
------ Follow up post added April 22nd, 2011 03:53 PM ------
You sure it is not STC4637? 4.5 pounds wholesale.
Old April 22nd, 2011, 05:54 PM
PaulMc's Avatar
PaulMc
Paul McConnell
Yes, it uses the just the two outer pins on the 3-way connector.
The Speedo Transducer only has male pins in positions 1 and 3, position 2 is omitted.
From RAVE -
Name:	C0195 - Defender 300Tdi Speedo Transducer.jpg
Paul.
Old April 22nd, 2011, 06:05 PM
Here: http://www.autosparks.co.uk/product_...oducts_id=1392 5.61 for the 3 prong plugs assuming those are the right ones?
Old April 22nd, 2011, 06:08 PM
PaulMc's Avatar
PaulMc
Paul McConnell
Yes, STC4637 is another option -
STC4637 / STC1189 - one supercedes the other (I'm not sure which way round )
http://www.brit-car.co.uk/product.php?xProd=99350
http://www.brit-car.co.uk/product.php?xProd=93216
AMR3334 - has a 2-way and a 3-way connector bound together in a short loom (this is the expensive one)
http://www.brit-car.co.uk/product.php?xProd=97514
Paul.
Old April 22nd, 2011, 06:14 PM
PaulMc's Avatar
PaulMc
Paul McConnell
That's the one
Also available from Autosparks, as a Male/Female pair -
http://www.autosparks.co.uk/product_...oducts_id=1771
As I said in my earlier post, they're available from most UK Auto-Electrical suppliers, as well as several sellers on eBay UK, but a large number of these won't ship outside of the UK.
Paul.
Old April 22nd, 2011, 06:36 PM
PaulMc's Avatar
PaulMc
Paul McConnell
Attachment 38068
I've just noticed - the AMP Econoseal Connectors listed by Ballenger Motorsports are not suitable
They're the Econoseal J [Mark II (+)] Series, the Speedo Transducer/NAS Lights use the Econoseal III, 070 Series -
http://www.tycoelectronics.com/catalog/pn/en/1-344273-1
This is good - a 3D pdf of the connector shell -
ENG_CVM_1-344273-1_K.pdf
Paul.
Old April 24th, 2011, 11:37 PM
surf110's Avatar
surf110
Ze
130 Project
Td5s only have 4 glow plugs.
Old April 25th, 2011, 12:47 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Newark sells the connectors, but they have a 38 day lead time right now, with none on the shelf....
http://www.newark.com/tyco-electroni...ono/dp/17R0280
Old April 25th, 2011, 05:36 AM
PaulMc's Avatar
PaulMc
Paul McConnell
They also require a minimum order of 500 units
Newark sell as Farnell in the UK.
It's quite annoying to think that you've found a supplier of a particular part, only to discover that they don't actually stock the item, but will happily accept an order for several hundred (or thousand) units
I only put the link to Tyco's Part Number to illustrate the difference between the Econoseal J [Mark II (+)] and the Econoseal III 070, as you would also require, in addition to the connector shell, the Terminals, Wire Seals and Terminal Lock to make-up a complete connector.
Paul.
Old April 25th, 2011, 06:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, Thats what I figured, seems odd?
Old April 30th, 2011, 07:13 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
These work perfectly, I got the pigtail version.
Anyone have a VDO hall effect laying around that they want to sell?
Attachment 38068
speedo
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Speedo Sender loykd Defender Technical Discussions 13 April 26th, 2005 09:20 AM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
