Connecting an obd reader on a 94 NAS D90 - Defender Source
Old August 15th, 2011, 11:50 AM
maleger
Marc-Andre Leger
Got a innova 3120 OBD 1 and 2 reader on sale today. I took apart the footwell in my 1994 NAS D90 to get to the ECU, but I can't sen to see a place where the reader would plug into. Anyone have some pictures of what I should be looking for ?
Am I missing something ?
Did I buy the wrong thing ?
I would like to leave the reader connected and mount it in my (custom built) cubby box, can I do this ? I can have a bunch of serial cables (old terminal stuff from long ago) so that is not a problem...
Old August 15th, 2011, 11:59 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Are you trying to tune? Or do you just want to read trouble codes? You don't need a code reader at all for that. It has a built in display.
Old August 15th, 2011, 12:08 PM
maleger
Marc-Andre Leger
Hi and thank you.
I have the LED reader, but it shows no codes on it. I do want to revive the Service Engine light and I want to have my own reader for expedition maintenance operations and to be self-reliant. Maybe tuning could be interesting, if I can I will surely look into it. There is software and I can probably use it with the on-board personal computer / laptop I installed on an extension arm (built from 3/4 galvanized gas pipes) on my cubby box.
Old August 15th, 2011, 12:19 PM
cellulararrest
Chris Snyder
Read this thread: http://www.defendersource.com/forum/...ht=code+reader
You don't need any external device to properly reset and read codes on the 14CUX.
The service engine light is a mileage thing and can easily be reset from behind the gauge cluster. If you have a fault code, you'll see an amber light that says "check engine" on it. That's when the two digit code will be displayed on the diagnostic display.
EDIT: And here is a list of all the fault codes. Print it out and put it in with your owner manual or something. That's all you'll need. http://www.robisonservice.com/servic...ouble.asp#1990
Old August 15th, 2011, 12:28 PM
maleger
Marc-Andre Leger
in the other thread they say there is no way to connect an and reader to the 1994 D90, I'm surprised ! Would chaing the ec to a 4.2 make any difference ?
Old August 15th, 2011, 12:34 PM
14 CUX use the same ECU.
Old August 16th, 2011, 11:39 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Is the ECU/fault codes the same for a 93 NAS D110?
Do, or do not, there is no try!
90, d90, nas
Series III half doors for a NAS 94 D90 Rufus Defender Technical Discussions 11 July 18th, 2015 12:38 PM
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
Any NAS D90 rough/project dnewman9 Wanted 11 October 12th, 2012 04:06 PM
'94 NAS D90 ST Door Skins Needed Green Blood Wanted 2 February 24th, 2009 07:41 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
