Connecting A/C to 94, missing connectors - Defender Source
Old September 4th, 2006, 04:24 PM
btate
Bryan Tate
d90
I picked up a a/c kit from a fellow board member. I believe it was the Rovernorth kit, looks like a 97 style inside. Anyway, the wiring harness was nicely labeled, but there is one set of wire with a red connector and another black that are suppossed to tie into the vehicle wiring. I don't have those wires off my harness, nor do I have the fuses or fuse "wires".
Does any one know the purpose of the those? and how to bypass? Hoped it was grounds and battery, but I heard a tie-in to the ECU so the computer can idle correctly to compensate for the draw of the a/c?
Anyway have a clue?
Old September 6th, 2006, 11:45 AM
btate
Bryan Tate
d90
Anyone have a circuit diagram that shows the A/C wiring clearly?
I have a 95 wiring diagram but it doesn't show the wires that tie into the a/c from what I can tell.
Someone has to have tackled this ahead of me
THanks
Bryan
Old September 9th, 2006, 06:16 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Brayn...I just installed an AC kit in my 95...did you pull up the passenger side rubber mat on the drive tunnel? under that mat are the two plugs you are looking for (at least they were on mine...I also have the wiring diagram but can't send it to you until next week when I get back to my office and a scanner...
Old September 9th, 2006, 06:53 PM
btate
Bryan Tate
d90
I think the problem is some 94's (maybe all?) don't have the harness you are referring to.
I have no A/C fuses. I know what I am missing, I am trying to figure how to "rig" a harness.
If I can figure what each wire does, I can try to tap into the existing setup.
I heard from one member who went thru the same thing, he found a way to rig it. But his truck was not nearby for him to tell me how to wire it.
Thanks for checking
Bryan
Old September 9th, 2006, 07:08 PM
Gkase's Avatar
Gkase
George Kase
I've got the schematic from my kit...I'll send it on Tuesday
Old September 10th, 2006, 07:18 AM
btate
Bryan Tate
d90
thanks
I hope that will do it
Do you want me to PM my fax#
Old September 10th, 2006, 08:05 AM
Gkase's Avatar
Gkase
George Kase
Yes...I'll do it first thing when I get in to the office...
94 A/C Vents mgrgpg Wanted 0 March 1st, 2006 09:25 AM
Installing '95 A/C in '94 jaherring Defender Technical Discussions 23 August 29th, 2005 08:12 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
94' Defender 90 A/C unit RX6RCROL For Sale - Parts 6 March 19th, 2004 08:41 PM
A/C unit for '94 Defender jracenstein Wanted 0 March 18th, 2004 01:39 PM
