Confused about oil pressure sender. VDO replacement - Defender Source
Old May 20th, 2010, 04:19 PM
sundogcwolfe
Charles R. Wolfe
1984 110, 300Tdi
Read the forum. Did the search.
Ordered VDO oil pressure 350-104 0-80 psi
Ordered sender 360 -009 1/8" NPT with warning light contact.
So far so good.
Got the adaptor 5 o ring to 1/8" NPT so I was ready.
Removed existing sender and no way was it 5-O ring. Appears to be 1/8" NPT !!! astonished look!
This is a 1985 110 originally gas now with 300tdi. Could the filte housing be off old engine thus different threading?
Is this really 1/8" NPT? Threads in nicely but could BPT be ral close?
Help please
Cwolfe
Old May 20th, 2010, 04:47 PM
I thought the 5 o-ring was for a V8. Are you sure you do not have the engines mixed up? Yes, 1.8" NPT and BSP are quite close...and also very close to 10mmx1....
------ Follow up post added May 20th, 2010 02:51 PM ------
OK, did a quick check. They are M10x1.
------ Follow up post added May 20th, 2010 02:57 PM ------
You need this: http://www.egauges.com/vdo_indA.asp?PN=R7960
Adapter Bushing - 1/8 NPT female x M10 X 1.0 male
------ Follow up post added May 20th, 2010 03:04 PM ------
This one looks to be higher quality... http://www.egauges.com/vdo_indA.asp?PN=ATM-2265
Old May 20th, 2010, 05:05 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I think the 5 o ring to 1/8" NPT was for 3.5 and 3.9 engines. I bought one too and have yet to put it in but after research the hell out of it I think that 5 o ring to 1/8" NPT was for the V8 engines.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 20th, 2010, 06:24 PM
sundogcwolfe
Charles R. Wolfe
1984 110, 300Tdi
Yikes!
Did I mess up?! The 1/8 npt went in fine. Now what? Do I need to retag before I use m1.0 x 10 adaptor?
Dangnabit this is frustrating
Cwolfe
ac
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 12:08 PM
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
