Confused... - Defender Source
Old September 29th, 2006, 12:41 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Confused...
GO drop the car of at the dealer because it was randomly dying. I was playing around under the hood and after advice given to me on this board cleaning the contacts on the MAF wire got it running again. It wasn't running perfect so I decided to bring it in to have the wire update done (apperantly there is one). I drop it off and a day later I get phone call back saying the car needs 3100 dollars worth of work. THey said the car won't run without an new air flow sensor. I"m thinking "i drove it down there and it was fine". THey can't get the part from land rover so they decide to change to fuel relays and do the wire update and magically teh car runs without a new $800 air flow sensor. THey told me i also needed a new rotor and cap which i happened to purchase and install 10 mins before driving it to the dealer. I"m guessing not but is there any merit in what they are saying? SHould I really drop for a new air flow sensor?
Old September 29th, 2006, 03:23 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
You asked the goldern questions. I can not comment on a dealer, but if you are unsure of its honesty, go for a second opinion. You can also call various government offices, including the local business bureu for complaints / reports on the dealership to see if they have had issues in the past. The fact you replaced two things - rotor and cap - and they flagged those either you installed them incorrectly (was the dealer recommending replacement pieces or just work) or that is suspect.
Most dealers are honest - just the hourly rate is so high and 15 m = $30 after a 1hr min. I cringe.
Old September 29th, 2006, 04:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I rarely trust dealerships and mechanics, all from personal experience. I think the worst case was when I had a bad starter, and the mechanic told me that the crankshaft was moving back and forth! Funny, the engine only had 2500 miles on it and the reason he gave still doesn't make sense to anybody.
Now, that being said, a bad MAF sensor will give you a trouble code. But those things rarely FAIL, most often it's just corroded or broken wires and connectors. And there was a manufacturing issue with them that does cause rough running at times, but doesn't warrant replacement (which usually gets you a part with the SAME problem in it).
But before I recommend a new sensor, what are the symptoms you are having? And what year truck?
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 30th, 2006, 08:39 PM
btate
Bryan Tate
d90
I just replaced my MAF, bought a used one for $100....
Just a thought.....the LR dealer put it on for me.
Constantly confused by bolt materials fenwaystan Defender Technical Discussions 7 August 24th, 2009 12:10 PM
Spedometer out - :confused paulb Defender Technical Discussions 2 October 31st, 2006 09:08 AM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
1998 Discovery LE RoverChic For Sale - Vehicles 9 September 13th, 2005 06:53 PM
Hub nut! TwisteD90 Defender Technical Discussions 22 September 28th, 2004 02:00 PM
