Confirmation GBR CV and stub? - Defender Source
Old November 21st, 2011, 11:28 PM
CDeWan
Clay DeWan
5.3L beastie
Can anyone help me confirm that the CV in the pictures is a GBR?
The half shaft appears to be beefier but the the CV is not laser marked with GBR and the CV half shaft is a little thinner than stock using a micrometer.
The axle and half shaft (short side) in pic 3 is laser marked GBR and is thicker than the CV stub axle on the one in question.
The question may be moot if the you can only use a GBR half shaft with a GBR CV.
ID:	43927   Click image for larger version
Old November 22nd, 2011, 12:39 PM
CDeWan
Clay DeWan
5.3L beastie
cv
never mind figured it out 24 spline - dah.
CV Joint Removal Lriwater Defender Technical Discussions 21 September 7th, 2009 01:36 AM
Long post regarding CV Joint/Swivel housing.. Emerson00 Defender Technical Discussions 16 June 12th, 2007 09:11 AM
» Defender Registry
110
Rugbier
# 115
wineryrover
Add your Defender
