Cone type air filter on turbo inlet - Defender Source
Old June 8th, 2016, 09:56 AM
Naplm00
Matthew
My air filter pulls air directly from the engine bay. And the element is gnarly and ready to be replaced.
Before I replace it, had anyone run a cone style (k&n type) air filter directly on the turbo inlet mouth? Ive had one previously on a 94 supra single turbo convert and it worked well but wanted to see peoples experience here.
I'd probably plumb the oil vapor air return line from the cyclone apparatus to a catch can as well.
Thoughts?
Old June 8th, 2016, 10:03 AM
you want to pull the coldest possible air so intake should be as far from turbo as you can route it
Old June 8th, 2016, 10:13 AM
Naplm00
Matthew
Yea currently with the setup I have the air is being pulled from about 12 inches away. I'm hemming and hawing over the seemingly negligible difference in heat from these two locations. Do you think that the increase in heat comparatively would outweigh the better filtration (when dry) and the increase in airflow?
Edit: forgot to mention I have a full width intercooler on the truck
Old June 8th, 2016, 10:19 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It depends on if you need extra airflow.
Just extra air will drop the EGTs a little, if that is a concern.
If not, you can adjust the fuel to match the extra air flow.
You'll get better performance by using a manual boost controller and cranking up the fuel some.
RDavisinVA
Old June 8th, 2016, 10:27 AM
Naplm00
Matthew
The chance at Lower egt would be better, since I'm am planning another pump tune in the near futur after wheel and tires go on. Currently running with minimal smoke and lots of power on a 1.2 and 33s with a boost pin, tweaked timing/fuel and a full. Width intercooler.
I'm getting the exhaust redone locally as right now it dumps under the passenger door sans muffler.
Old June 9th, 2016, 10:55 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Throw a filter on the turbo. I built turbo cars for years, yea cooler air helps some, especially with cars that have a mass air flow sensor pre turbo (as the intake air temp sensor is usually on the MAF). This truck has none of that. 12" isn't going to change much.
The turbo is going to heat the air up, and the intercooler SHOULD cool it. You also have a big intercooler to help with that. Same thing as your Supra.
Old June 9th, 2016, 12:04 PM
Naplm00
Matthew
Thx for all the insight folks, ill give it a go and report back.
Old June 9th, 2016, 12:56 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Located mine behind the passenger side headlight. Seems like a decent spot for cooler air. In full disclosure, I don't have many miles on this app yet but so far so good.
Old June 9th, 2016, 01:11 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
That's what my dad had done on his, I put mine straight on the turbo, but it's a defender so I don't know if that makes a difference heat wise, i haven't noticed anything negative yet.
Old June 9th, 2016, 01:15 PM
Naplm00
Matthew
So I can be lazy. What size was the inlet on your defender engine 200tdi?
Old June 9th, 2016, 01:21 PM
PabloCocito
Pablo Cocito
The filter is 3" and way too big, the adapter I bought was from 3 to 2 1/2 and it fits about right.
Old June 9th, 2016, 03:02 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Stock pipes are 2".
RDavisinVA
Old June 9th, 2016, 03:14 PM
Stock pipes are 2".
Turbo inlet is 2.5". Intercooler piping is 2".
Old June 9th, 2016, 06:38 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I heard to avoid kn filters if you go off-roading. They will not filter as well and pooch the turbo. If you stay on road go for it as the cfm increase makes a big difference...exhaust and filter = ~ 10-15 hp gain
Old June 10th, 2016, 07:28 AM
1of40's Avatar
1of40
1of40
I've also heard from those that race off road KN makes perfect fine filters for off road use. Probably depends which filter.
Old June 10th, 2016, 08:36 AM
Naplm00
Matthew
Where did you plumb the oil vapor return line to?
Old June 10th, 2016, 10:21 AM
1of40's Avatar
1of40
1of40
Haven't decided what direction I'm going on this yet. I need to do some more research re the do's and don't, why and why nots.
Old June 10th, 2016, 10:26 AM
Naplm00
Matthew
So right now, just venting to the ground? Also I picked up a filter wrap for mine that is going in. They are waterproof and act as a pre-filter keeping the mesh/foam dry.
Old June 10th, 2016, 03:22 PM
1of40's Avatar
1of40
1of40
Yes, at the moment its pointed to the topside of chassis. last I looked there was no accumulation there yet. I'd read one guy plumbed his into the chassis which is creative.
Can you post a link to where you got your pre-filter?
Old June 10th, 2016, 03:42 PM
Naplm00
Matthew
Filterwears Pre Filter K301K Fits K N Air Filter RF 1037 Filter Wrap | eBay
Send them a message with your part number or dimensions and they should point you to the correct version. It's about 1/2 price of the kn version.
P38 air suspension reservior inlet? RockShow Defender Technical Discussions 7 November 1st, 2015 07:48 PM
2.8 Turbo Inlet Gasket Overlander Defender Technical Discussions 3 January 23rd, 2015 04:37 PM
200tdi diaphragm and cone tomaco1 Defender Technical Discussions 0 September 8th, 2013 07:41 AM
1997 BRG Traffic Cone for sale rijosho The Flea Market 3 July 12th, 2010 11:04 PM
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
