Cone type air filter on turbo inlet - Page 2 - Defender Source
Old June 11th, 2016, 10:15 AM
cdb
Clark Bowen
Originally Posted by 1of40 View Post
Located mine behind the passenger side headlight. Seems like a decent spot for cooler air. In full disclosure, I don't have many miles on this app yet but so far so good.
I think your air cleaner might be too small and restrict your air flow.
The stock 200/300TDI air cleaner is pretty good size, but yours appears to be much smaller.
I initially used a large cone K&N filter on my Mercedes 5 cylinder diesel but it made a strange sound at higher rpms.
When I calculated the outside dimensions of the K&N air filter for the stock Mercedes air cleaner I found that my cone filter only had about 75% of the surface area of the stock one. This seemed to be a reasonable approach to getting the right surface area for a K&N filter because they are very coy about the CFM figures for each filter even though they go on a length about all their testing and measurements.
Here is a K&N air filter for a 1995 200/300TDI: http://www.knfilters.com/search/product.aspx?prod=E-2590. I calculated the outside surface to be about 182 square inches (11.313" x 3.141592 x 5.125")
Then I went to this page to find a suitable cone or cylindrical filter: http://www.knfilters.com/search/universal.aspx.
It took me a while using this calculator and the measurements for the area I had available to install it, but I found a quite large cylindrical filter that is about the same surface area as stock. However, the Mercedes 5 cylinder diesel only needs about 150 square inches so yours would have to be even bigger, but I'm quite sure that your existing one is much smaller than my original cone filter..
2011 RR HSE -
2001 GMC 2500 4wd
Old June 11th, 2016, 10:32 AM
I've also heard from those that race off road KN makes perfect fine filters for off road use. Probably depends which filter.
Sponsorship money will get a fellow to say most anything. There was a study done by a fellow in OZ that I posted a link to years ago showing which filters did the best flow, ie an impartial scientific test. The stock paper filter beat the k&n, but the best was the donaldson filter used on the wolf 300 tdi's, it smoked all other filters.
The write up can be found on the AUlro forum.
Old June 11th, 2016, 10:38 AM
Naplm00
Matthew
I ended up with a foam twin air style cone filter with inverted top., we shall see
Old June 11th, 2016, 10:40 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Sponsorship money will get a fellow to say most anything. There was a study done by a fellow in OZ that I posted a link to years ago showing which filters did the best flow, ie an impartial scientific test. The stock paper filter beat the k&n, but the best was the donaldson filter used on the wolf 300 tdi's, it smoked all other filters. The write up can be found on the AUlro forum.
Yes, I remember reading that write up. It was very well done too. I need to revisit the Donaldson site and think through this again one day.
------ Follow up post added June 11th, 2016 10:42 AM ------
Originally Posted by cdb View Post
I think your air cleaner might be too small and restrict your air flow. The stock 200/300TDI air cleaner is pretty good size, but yours appears to be much smaller. I initially used a large cone K&N filter on my Mercedes 5 cylinder diesel but it made a strange sound at higher rpms. When I calculated the outside dimensions of the K&N air filter for the stock Mercedes air cleaner I found that my cone filter only had about 75% of the surface area of the stock one. This seemed to be a reasonable approach to getting the right surface area for a K&N filter because they are very coy about the CFM figures for each filter even though they go on a length about all their testing and measurements. Here is a K&N air filter for a 1995 200/300TDI: http://www.knfilters.com/search/prod...px?prod=E-2590. I calculated the outside surface to be about 182 square inches (11.313" x 3.141592 x 5.125") Then I went to this page to find a suitable cone or cylindrical filter: http://www.knfilters.com/search/universal.aspx. It took me a while using this calculator and the measurements for the area I had available to install it, but I found a quite large cylindrical filter that is about the same surface area as stock. However, the Mercedes 5 cylinder diesel only needs about 150 square inches so yours would have to be even bigger, but I'm quite sure that your existing one is much smaller than my original cone filter..
Dude, thanks for sharing. Looking forward to reading up on this.
Old March 31st, 2017, 08:52 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I think I am going to try doing a setup like this quick on the dyno to see if it nets any gains over the factory setup. Ill just pull the intake to see if it gets any power. If it does ill fab something clean and simple up like this. I don't need the extreme weather protection the factory intake provides.
Old March 31st, 2017, 09:15 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I wonder if this would work in a 200tdi stock air box?
Old April 1st, 2017, 07:31 AM
1of40's Avatar
1of40
1of40
That would be great to see what measurable difference there is. This filter is a little bit noisier on long trips at max highway speeds but around town and short commutes to work it has been fine so far.
Old April 3rd, 2017, 08:05 AM
AdamSanta85
91' D90 200TDI
This one will work for sure, just not cheap.
LAND ROVER DEFENDER 200 TDI K&N AIR FILTER. PART NO: NTC6660K | eBay
Also this "Pipercross" brand. Allisport sells this one
http://www.pipercross.net/pipercross..._p24037574.htm
https://www.lrdirect.com/BA5812-Air-Filter-Pipercross/
P38 air suspension reservior inlet? RockShow Defender Technical Discussions 7 November 1st, 2015 07:48 PM
2.8 Turbo Inlet Gasket Overlander Defender Technical Discussions 3 January 23rd, 2015 04:37 PM
200tdi diaphragm and cone tomaco1 Defender Technical Discussions 0 September 8th, 2013 07:41 AM
1997 BRG Traffic Cone for sale rijosho The Flea Market 3 July 12th, 2010 11:04 PM
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
