Condenser Fan Switch where is it? - Defender Source
Old August 5th, 2009, 06:16 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Can someone tell me where there switch is for it on a 97. Also what does the senor right behind the driver side motor mount go to? I have the shop manual and the factory parts book can not seem to find either in it.
Old August 6th, 2009, 07:33 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
You mean to tell me no one knows where this thing is? I know there is a coolant temp senor up by the thermostat does it control the condenser fan also? There is also the temp sender there. Someone, Anyone.
Old August 6th, 2009, 11:30 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Hi Dana,
The fan is controlled by the ECU and the sensor is a Knock Sensor. There should be one on the other side as well.
HTH
Ian
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Not sure about the V8 engine, but on the Tdi it's right under the
cooling system elbow that comes out of the thermostat housing,
2 thermoswitches there.
- Charles Eames
fan, switch
'93 NAS D110 AC Condenser Fan Jon_Winningham Wanted 19 January 17th, 2015 11:49 AM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
