Computer temp - Defender Source
Old May 21st, 2012, 01:05 AM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Computer temp
Where does the computer get the engine temperature?
In an effort to rule out high temps, I hooked up my hand held reader and the temp reads say 205.
The more or less brand new gauge and temp sender says 225 and the IR thermometer at the temp sender reads about 190.
Old May 21st, 2012, 01:34 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
On a 97 there is a seperate sender for the ECU. It's the 2 pin black one in the pic below. The temp gauge runs off the gold colored one behind it.
Name:	Temp Sender.jpg
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
