Compression values on a 4.0? - Defender Source
Old October 11th, 2015, 10:46 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I have searched and searched for this answer but no luck.
Did a compression test today on my 4.0 but have no idea if the value is good and in range.
Only tested two cylinders as I was having a misfire on #2-
Both were at about 160 on the gauge.
Is that within specs? Just want to know I am looking.
Old October 11th, 2015, 10:57 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Should be in the repair manual. Does seem in the right range. Shouldnt be anymore then 10psi's(?) difference between any cylinder.
Temp Sensor Values - I'm Not Sure if its Overheating! Stmpede Defender Technical Discussions 2 April 5th, 2012 01:11 PM
130 values Jblake For Sale - Vehicles 25 January 22nd, 2012 08:47 PM
Various Diff bolt torque values? KevinNY Defender Technical Discussions 1 December 16th, 2010 03:54 PM
alternator circuit voltage drop and ripple voltage values JFD Defender Technical Discussions 2 November 29th, 2010 08:13 AM
fuse box diagram and amp values? Gkase Defender Technical Discussions 0 April 7th, 2010 02:22 PM
