Compressed Air Tank Fitting Help - Defender Source
Old December 11th, 2015, 02:52 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I took my CO2 tank in to be filled and now I am missing the small brass "restrictor" that threads in to the tank before the regulator threads on. Does anyone know what this part is called or where to get it? I've tried The Source (where my tank is from) and Powertank spare parts pages with no luck.
Is this fitting even necessary?
Cheers
Semper Fi!
Old December 11th, 2015, 03:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
Ok, just called Powertank. That brass fitting is actually a seal (it has an O ring on it), and is the old way of sealing the regulator to the tank. It's not required, nor is it a "restrictor." If the regulator itself has an internal O ring, then this brass fitting is not needed.
The best part of this is old age. I took the fitting out and put it in a safe place so I wouldn't lose it. Now I can't remember where I put it - that was only 2 weeks ago!
Semper Fi!
Old December 11th, 2015, 04:04 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Dig you man, my wife put my 110 serial number (stamped plate) in a "safe place". Found it a couple of month after the inspection... Bought a new personalized plate for that occasion as no vehicle can pass the inspection without it! 50£
Compressed spring height jayz Defender Technical Discussions 2 December 14th, 2014 02:49 PM
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
NAS 90 snorkel air intake fitting rankar Wanted 3 November 23rd, 2013 04:08 PM
Russell ARB Air Locker Adapter Fitting Kit The Dro For Sale - Parts 0 March 1st, 2011 06:32 AM
Front Runner water tank fitting Overlander Defender Technical Discussions 10 August 6th, 2009 03:49 AM
