Completely lost all control of steering today - Page 2 - Defender Source
Old January 4th, 2011, 12:40 PM
carlosz's Avatar
carlosz
Carlos
next time use a pickle fork to separate the ball joint, if said tool does not hold the ball joint you can use a ball joint separator, looks like two fingers and a thumb with a bolt in the middle. lastly a good whap with aball peen hammer on the ouside of the loop allways works. good collection of front end tools.
http://www.google.com/url?sa=t&sourc...EJKYSouO10PyuA
Old January 4th, 2011, 01:04 PM
The Dro
Dro
1988 Ninety
I used one of these from Auto Zone and they are a POS... I broke two of them. I ended borrowing a HD one and got the job done. (I guess the penetrating oil, heat, hammering, cursing... helped too).
Old January 4th, 2011, 07:07 PM
carlosz's Avatar
carlosz
Carlos
Pedro you are such an amateur. lol...
Old January 4th, 2011, 07:40 PM
The Dro
Dro
1988 Ninety
Hey... They rent for FREE... who can beat that...
And the job got done...
Old January 5th, 2011, 12:38 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I think this is poorly designed. Don't see any advantages to it. Also think the steering damper attachment sucks.
I took the pitman arm for a D1 (fits on the D90 steering box). This then allows you to use a proper TRE. This is much easier to service, replace, and fix. You must also change the way the steering damper is attached. But I think this is an upgrade too.
See the pic below.
Name:	new steering.jpg
Old January 5th, 2011, 10:35 PM
I have one of those and it works great. Never had any problems. Also ever had any problems just knocking them out with a hammer and the nut run up to the end of the thread either, even though everyone says you should never do that.
I have broken the large threaded end of a tie rod end where it threads into the rod itself. That was a surprise. Have had better success since.
Old January 6th, 2011, 10:39 AM
Use two hammers and sandwich the part you are trying to free. They just pop out.
Ron
------ Follow up post added January 6th, 2011 10:40 AM ------
I tried heat, penetrating oil, voodoo... you name it.
3ft pipe wrench?
Old January 6th, 2011, 11:29 AM
The Dro
Dro
1988 Ninety
I've always used them and had no issues.
The RRC I had, came from upstate NY and EVERYTHING... was rusted shot....
hell, even the aluminum panels had rust (just kidding for the ones that cannot read between the lines )
Ron
3ft pipe wrench?
I used a 24" breaker bar and ended up braking the removal tool... but that was a while back on the RRC... now a have the DI.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
