Complete, full door removal - Defender Source
Old April 17th, 2016, 07:42 PM
Tesla1Defender
97 D90 NAS SW
97 D90 SW. Want to completely remove door, getting new ones.
Is there a particular order to remove door completely?
I think:
1. undo speaker wire and pull wire through loom
2. remove cotter pin and tap retaining bolt out (See picture)
3. then remove pair of hinges
Just want to be sure I am not missing something here.
OR should I remove hinges first then cotter pin and retaining bolt?
ID:	147473   Click image for larger version
Old April 17th, 2016, 08:18 PM
Hinges last. The rest in any order.
Originally Posted by pendy
I'm here for the D's
Old April 17th, 2016, 08:31 PM
Tesla1Defender
97 D90 NAS SW
Thank you
Old April 17th, 2016, 08:33 PM
Also leave it latched closed when you remove the hinges, keeps it from, you know, falling on you.....
95' D90 - daily driver..
Old April 17th, 2016, 08:41 PM
Tesla1Defender
97 D90 NAS SW
Actually good point, thanks
Old April 17th, 2016, 08:54 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
BTW...are the hinges posi drive or regular Philips screws?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 17th, 2016, 09:03 PM
Depends... I think stock screws are posi drive and most of the Stainless kits are Phillips.. Either way a big #4 screw driver or bit is in order..
Old April 17th, 2016, 09:13 PM
Tesla1Defender
97 D90 NAS SW
Phillips, non-stock hinges. sprayed some PB blaster oil to soak in
door
Complete 2 door 109/110 Aluminium Top, sides/roof/door speedpin For Sale - Parts 8 November 4th, 2015 10:24 AM
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
110 top, 3-door solid sides, full rear door Method PHX For Sale - Parts 7 March 10th, 2006 04:07 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
Full door chrisvonc Wanted 0 July 9th, 2004 11:31 AM
