Complete Exhaust Replacement $$? - Defender Source
Old April 12th, 2011, 10:40 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
What is the best price on a complete stock exhaust replacement for a 3.9 94 D90? Is there really any performance (mpg) improvement grained from paying up for the more expensive upgrades?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old April 12th, 2011, 11:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do you need a full system or just cat back?
Old April 13th, 2011, 01:05 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Don't waste your money on exhaust if you're chasing performance. If you want a nice, non-rusty exhaust that's tucked up out of the way, then go the custom route. I had a custom Y-pipe setup made locally. They used some "high performance" cats, whatever that means. They tuck up nicely out of the way and my exhaust is no longer a rusty pile of shit. Cost: about $900.
Old April 13th, 2011, 12:09 PM
dsh12
Daniel Hayes
Full System.
Dan
Old April 13th, 2011, 12:36 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Wow, was most of that the cats, or was it stainless? I've had full exhausts done for a lot less than that. Had a system built for an old BMW coupe for about $300 that is similar work and content to a Landy system less the cats -- two downpipes with flanges, y'd into a single 2.5" to the back with a Magnaflow and a nickel tip.
You can buy universal fit cats from Summit for $60-$90 each.
Tony
1984 110 "Smokey" (sold)
Old April 13th, 2011, 03:32 PM
dsh12
Daniel Hayes
Was the Magnaflow included in the $300? Who did the work?
Dan
Old April 13th, 2011, 03:56 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I just had new performance cats, a stainless Magnaflow muffler, and tail pipe section from the muffler back put on a few months ago. Cost $900. I was surprised at the performance gains. I did not expect anything other than a better sound.
What I found was that now on my daily commute there are hills that I would have normally had to downshift to 4th gear I can now stay in 5th gear. I find myself running around in 5th gear more and turning 2,000 rpms instead of running in 4th at 2,500 rpms.
Because I get reimbursed for mileage I am constantly resetting my odometer so I do not know if I am getting any better gas mileage.
I am thinking that my old cats must have been partially plugged and that is why the new system allows for better performance.
Old April 13th, 2011, 05:52 PM
dsh12
Daniel Hayes
What was the Magnaflow muffler & cats model number?
Dan
Old April 13th, 2011, 06:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
Also could do the whole NRP set up from RN.
Old April 14th, 2011, 03:39 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Yes, muffler included. It was at a muffler shop near the airport in Portland, OR, about 5 years ago.
Tony
Old April 15th, 2011, 01:30 PM
Craigd's Avatar
Craigd
Craig Dickson
Dan,
Just talked to my muffler guy and the part numbers are
Magnaflow muffler #12256
The cats are from a company called Imco and the numbers are
Left side #650305
Right Side #650005
Apparently the Imco cats are only available through custom shops so you will have to get them through a shop that uses them.
My muffler guy does not use Magnaflow cats as they were having troubles with them and he likes the Imco cats better or so he says.
Old April 16th, 2011, 05:13 PM
dsh12
Daniel Hayes
Dan,
Left side #650305
Right Side #650005
So its 2 1/4 off of each manifold 'Y'ed into a single 2 1/2 to the muffler?
Dan
Old April 18th, 2011, 01:31 PM
Craigd's Avatar
Craigd
Craig Dickson
Yes a y pipe into a single muffler
ac, exhaust
Stainless exhaust replacement suggestions? stnmikita Defender Technical Discussions 10 December 23rd, 2011 02:30 PM
Exhaust replacement kolvedic Defender Technical Discussions 1 March 29th, 2009 11:21 PM
Exhaust Replacement kleedee Defender Technical Discussions 34 January 10th, 2009 02:40 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
