Cold Weather Door Latch Issue - Defender Source
Old January 17th, 2012, 05:20 PM
midturtle's Avatar
midturtle
Wes
'95 90 SW #234
Does anyone know of any tips to get the door to latch during the winter months. I'm in an area of WY that is always below freezing and frequently single digits or colder. It seems that when the outside temp hits the teens, my door latches just don't want to work. It seems like they freeze up and won't latch. It makes for a chilly ride. Any suggestions?
Old January 17th, 2012, 11:00 PM
Naplm00
Matthew
Mine were going this too. I just greased them with white lithium. Bingo solved
Old January 17th, 2012, 11:15 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
One thing that adds to this problem is the door seals get stiff in the cold, don't know what can be done about that though.
Old January 18th, 2012, 06:03 AM
RR Classics have heated door locks. Maybe you could adapt the lock barrel heater from one of those.
Old January 18th, 2012, 03:19 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I your door seals are old they'll be more stiff than new ones. For the lock the only option in very cold weather is something like a moly grease rated for that temperature range and cleaning out any waxing before application and then changing it in the summer since it'll probably run out when warm. That being the 'right' way, if you lube with something like light machine oil (3in1 is a brand) it'll probably stay more fluid than a lot of the spray and evapourate type lubricants. (and never ever lubricate with WD40 or any other penetrant, they're solvents not lubricants).
Hope that helps, the more fun one is when the doors freeze onto the door seals themselves, I'm going to put on one of the aftermarket seals at some point and experiment with different treatments to stop it... I'm guessing that regular application of something like armorall might work...
Old January 18th, 2012, 03:47 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I have run into this problem. I have found that squirting with a little hoppes Dri-lube works fine for me. I have had the door seals freeze with water on them before. that sucks.
door, door latch
Cold Weather Starting the 200 TDI; Trials and Tribulations from Colorado paluskat Defender Technical Discussions 9 February 5th, 2011 03:58 PM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
