Cold starts fine, intermittent start after - Defender Source
Old July 27th, 2016, 02:12 PM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
94 NAS 90 stock 3.9 engine.
Truck cold starts just fine. When turned off and left for an hour or so the truck will just crank. Come back in another 30 mins or more the truck will start just fine. This phenomenon has been occurring regularly for the past month. Have replaced the following one by one trying to figure out the problem with no luck:
Ignition module (moved to the aftermarket plate attached to the ignition coil)
Ignition coil
Distributor cap, rotor, spark plugs and wires
ECU next?
Any help greatly appreciated!
Do, or do not, there is no try!
Old July 27th, 2016, 03:54 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
fuel pump?
Old July 27th, 2016, 04:09 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Cold start sensor? And some grounds poop out when a rig heats up? - both more associated with stalling once hot, tho.
Old July 27th, 2016, 04:28 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Test the fuel temp sensor.
Old July 27th, 2016, 05:01 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
http://www.defendersource.com/forum/...rms-60988.html
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old July 28th, 2016, 07:44 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Originally Posted by Shagey71 View Post
Took a look at this thread and seems like the problem there is a little different than what I am experiencing. The truck will fire up np problem if left for 10-15 mim after shutdown. When left for 60-90 minutes it cranks nice and strong but will not turn over.
Fuel pump was replaced a couple of years ago and there is good fuel pressure.
How and where do I check the fuel temp sensor?
The above thread also mentioned coolant temp sensor, but did not fix the problem. Same question how and where do I test it?
Thread stopped with replacing the starter, but no report back on the outcome.
Old July 28th, 2016, 08:04 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Fuel temp sensor is on the front of the fuel rail. Helps to control hot starts. Coolant temp sensor helps with cold starts but since you're testing anyways. It's on the top of the intake manifold with the two wire connector. Sensor with the single wire on the other side is for the gauge.
You can test on the sensor if you don't want to dig out the ECU.
Name:	Screenshot 2016-07-28 08.51.40.png
ID:	154690   Click image for larger version
Name:	Screenshot 2016-07-28 08.52.00.png
Old July 28th, 2016, 11:07 AM
Shagey71's Avatar
Shagey71
Sam Hagey
You mean it won't start, but it's turning over and your belts are spinning, etc. Right?
Old July 30th, 2016, 09:09 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Originally Posted by Kevin88RRC View Post
Fuel temp sensor is on the front of the fuel rail. Helps to control hot starts. Coolant temp sensor helps with cold starts but since you're testing anyways. It's on the top of the intake manifold with the two wire connector. Sensor with the single wire on the other side is for the gauge. You can test on the sensor if you don't want to dig out the ECU.
Does this apply to a 97 gems system too? Having hot start problems... Engine turns over but stumbles.... Doesnt catch to start...
Old July 31st, 2016, 11:21 AM
carlosz's Avatar
carlosz
Carlos
yes, all fuel injected systems use a coolant sensor to help ecu verify fuel mixture when it compares to oxygen sensor data.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old July 31st, 2016, 12:38 PM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Yes that is what I meant. Going to test fuel temp and pressure this week.
Old August 2nd, 2016, 07:31 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
So quick update... I had a crappy battery that would turn the starter over (I.e. had enough amperage) but overtime the voltage would drop on it. So I believe that what I thought was a sensor problem not allowing correction for the hot engine/fuel was an issue with the battery. The amperage was enough to turn it over albeit slowly but the voltage was too low to run the ecu..... Put a new battery in and it runs great.... Could be a fluke though... Will let you know if this changes.
start
Def 110: intermittent loss of acceleration, white smoke, dying after accelerating lro Defender Technical Discussions 3 October 13th, 2015 05:09 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 11:17 AM
starts fine unless ignition switch left on.... Davis Defender Technical Discussions 7 June 10th, 2010 12:14 AM
Cold Starts JBfoot Defender Technical Discussions 0 November 3rd, 2007 05:45 AM
surprised at 300Tdi cold weather starts Gkase Misc. Chit-Chat 6 December 6th, 2006 08:11 AM
