Cold starting ideas - Page 2 - Defender Source
Old March 2nd, 2014, 01:47 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Originally Posted by tjfslaughter View Post
I went to the garage this morning to see what I used for my generator. It does have a warning label for engines with glow plugs. My generator does not have a glow plug installed.
'Twas what I used as well... Hit up the Diesel 911 as well as antigel today.
Old March 3rd, 2014, 12:04 PM
I have no problems starting my 200tdi and have never used my glow plugs. Byrne, i think we should talk at some point about your wiring. your battery regardless of size should last for more than one crank.
Old March 3rd, 2014, 02:04 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I know my wiring has been screwy but it seems to mostly be sorted out. Everything I've mentioned prior in the forum (starter issues, relay issues, and ground issues) either I or a specialist sorted out (mostly the latter).
For a while here it was a high in the negatives and I didn't have anywhere warm to park it so the battery was very very cold for several weeks. I've noticed a huge difference between say -5F and 25F with the battery. It's an optima red top I got in September FWIW. I have since bought a battery blanket which pretty well ended that problem; rereading my last post I see I wasn't very clear about that.
Overall though my engine hates running in weather that cold and has significant power loss until it warms up a bit.
best battery for cold starting 200 tdi Sandt Defender Technical Discussions 6 October 31st, 2012 08:01 PM
Cold starting problem td5 pkneale Defender Technical Discussions 20 March 21st, 2012 10:56 PM
Cold Weather Starting the 200 TDI; Trials and Tribulations from Colorado paluskat Defender Technical Discussions 9 February 5th, 2011 03:58 PM
Hard starting while cold. Hans Defender Technical Discussions 0 December 5th, 2008 03:51 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
