Cold start problem - Defender Source
Old February 10th, 2008, 09:51 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Cold start problem
Yet again I'm having cold start problems. As in the starter doesn't want to work. I just replaced on Friday my old starter that died on me. This new one worked fine Friday after I installed it and started tonight when i went to my parent's house. I've got a dual optima set up. One is a 6-7 year old red and the other is a 3 year old blue top. Not sure if its the batteries since I still have power. I get a hum from the fuel pump and a click from the starter relay. I checked the 60 amp fuses under the hood and they looked fine. So I'm wondering if the new starter was a bad one? More so what the heck is going on with this thing? I'll be heading back to my parents tomorrow to play around with it. Any ideas would be greatly appreciated.
Jimmy Buffett
Old February 13th, 2008, 05:42 PM
could be a bad connection in the starter relay that passes the power to the positive lead on the starter, or just a bad relay itself. I have a J**P that has the same issue, and I'm going to replace the starter cable next week.
Old February 13th, 2008, 06:03 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would start by checking my grounds. Try running a jumper cable from the ground terminal on the battery over to the starter--that at least can rule that out.
Old February 13th, 2008, 06:52 PM
flippedrover
Tyler
'94 D-90
With a little work and about an hour on the phone with Trevor I figured its a problem between the relay and the starter. I currently have a wire running from the starter to the battery so I can get around untill its warmer out.
Jimmy Buffett
start
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
