cold Idle and stalling issue (3.9 EFI) - Defender Source
Old August 16th, 2015, 10:26 AM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Ok,
I have a 3.9 EFI installed with ZF auto in my 1988. Since the conversion we have had a problem with the engine progressively running worse over time. Unplugging the battery to reset the system results in better operation for a short bit and the cycle continues. We thought the primary issue was that we did not have a transducer installed resulting in too rich a mixture. Added a transducer and it does appear to be better but still having some issues. When starting the truck cold it seems to stumble and search for idle. It eventually evens out but once I put it in gear and apply a little pressure to the accelerator it wants to stall. It acts starved or flooded, hard to tell. More pressure applied gets it going relatively smoothly but if I quickly take my foot of the accelerator or come to a stop it tries to stall. It appears to get better as the truck warms up. I have only driven it about 50 miles since the transducer install so it could still be the same problem as before. Will drive more today to see if it evens out, stays the same or continues to progress in the evil cycle. Any ideas?
Also, the fuel gauge is not functioning properly. It goes to empty when the car is off but seems to read 3/4 full regardless of fuel level when on. I know the mechanic had a fit getting the gauge to read at all but not sure this is any better. prior to the engine and transmission replacement the gauge worked fine - a quick search shows that it is likely a grounding issue. my question here is how many of you have fuel gauge issues? Seems that many of us defender owners just use our miles trip counter?
Old August 16th, 2015, 10:45 AM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I use the trip odometer even though my gauge works,as I have had grounding issues in the past and when I figure out the gauge is inop, I will be out of fuel.
As for the motor stalling, my guess is the idle air control.
Just my $0.02
Old August 18th, 2015, 01:33 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Was the efi pulled from a vehicle running/running well? What are the qualifications of the mechanic who performed the conversion? Codes?
As far as the gas gauge goes, if tinkering with the ground doesn't help, you can always drain the tank to see what it reads @ actual empty and @ actual, say, 1 gallon? Mine stays on "Full" until it's pretty darn low & then starts moving to 3/4 where it's @ actual empty. I wouldn't settle for a haywire gauge reading without at least replacing the sender & gauge after ensuring that it's not simply the ground.
Old August 18th, 2015, 10:41 AM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Great questions cowboy. I was told that everything was good on the engine it came from but I cannot confirm that. I have been driving it each day to work out the bugs and there are some specific symptoms that have become consistent:
1. when sitting overnight the truck struggles to idle when I crank it in the morning. It will hunt for a consistent idle and then, once the engine starts to warm, settle in and smooth out. It does not stall if left alone during this process but can stall if I tap the accelerator
2. once the engine is warm it runs well and seems to maintain a good idle
3. Once warm and running more smoothly it is still possible for me to quickly press and release the gas pedal and cause the truck to stumble. it corrects itself after stumbling and does not stall
4. When parked for several hours and the engine cools down it may still run a little rough upon start but transitions much faster than when sitting overnight.
5. The idle hunting does not feel like a traditional misfire and I do not get any noticable blue or black smoke out of the exhaust
I am leaning towards a throttle body or idle control valve issue - any additional thoughts from the experts?
Old August 18th, 2015, 12:19 PM
Matt_110's Avatar
Matt_110
Matt
110
It sounds like it could be the Stepper Motor
1987 110, 2.8TGV, ZF Auto
Old August 18th, 2015, 12:42 PM
First things to check for are vacuum leaks. These can be a missing or cracked hose, a bad seal between the plenum housings, or even a stuck-open stepper motor. Vacuum leaks will give you fits, making you think you have all kinds of problems when you really don't.
Next is to be sure that you are getting good fuel flow. Starvation from low fuel pressure can also make the engine run poorly.
Lastly check on things like missing or inoperative sensors, road speed sensor, map sensor, etc. Also be sure that you have a good battery that you're not experiencing low voltage or bad grounding issues.
That should give you enough to poke at this evening...
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Could it be poor fuel pressure? Maybe from the pump about to head south?
Old August 18th, 2015, 01:11 PM
cowboy
steven
A stepper motor and/or a MAF sensor problem is sometimes just that your existing ones need cleaning, right? And there is also something for those EFI systems called a "pvc kit" - would a pvc kit address some of the problems that 02batsea listed?
No expert, but I have been stalking similar symptoms on a '91 RRC oem efi...
Old August 18th, 2015, 02:05 PM
You really need to take the workshop manual and go through a check of each item. Anything else is hunting in the dark. The troubleshooting guide in the manual is easy to follow and you will rule out each item.
Are ALL of teh sensors from the original vehicle installed?
Old August 18th, 2015, 02:14 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Red90, I don't really know the answer to your last question. I will try to find out. I am going to try to take a look / clean the MAF and stepping motor as well as check fuel pressure. I am starting to wonder if I have a problem with the fuel pressure levels dropping over night. Will let you all know if I find anything out.
On a different note, I am very new to dealing with defenders. I have driven a 1995 RRC for the last 12 years and have very little issues with them. I am mechanically inclined and pretty analytical when I can dedicate time to things, but have little experience with working on these trucks. Where can I get a correct workshop manual? Those are very helpful and I restored a 65 mustang when in high school by using one.
Old August 18th, 2015, 02:25 PM
cowboy
steven
The MAF supposedly has particular sensibilities. You might want to pick up some of this: CRC Industries 5110 - Mass Air Flow Sensor Cleaner | O'Reilly Auto Parts
Old August 18th, 2015, 02:34 PM
Lets test the amplifier and coil to see if the spark is consistently strong. Parts that you will need some day that are well worth buying include Dizzy cap. plug wires and rotor.
Mine stumble and stalled at cold. Ran ok with slight misfire when warm. Utimately cured with new cap and rotor.
cowboy
steven
The manuals are all or mostly downloads...Google it, but this is what I had bookmarked: pdf Land Rover Manuals | Landroverweb.com
Old August 18th, 2015, 02:54 PM
Originally Posted by Brentflyfish View Post
Ok,
Air idle control valve is a very common fault that would lead to the symptoms you decribe.
You can unplug it and unscrew it from the plenum and give it a spraying with a copious amount of carb cleaner ... often that will clean the residue that makes it sticky.
alternatively non-genuine spares are cheap.
Old August 18th, 2015, 03:03 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
In the past you had replaced yours with AICV from Autozone? Is still holding well, or you had replaced them with something else? Is the AICV located on the top left corner of the plenum when facing the plenum?
Old August 18th, 2015, 03:32 PM
I cleaned my original and put it back in after using the autozone one for a while. Both work equally well. And yes it's where you describe.
Old August 18th, 2015, 03:41 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Very good advice. Like most have said clean the stepper.
What vehicle is the engine out of? I can you a link to download the RRC 87-91 which covers the 3.9 and should provide all the info for trouble shooting this engine.
Old August 18th, 2015, 05:30 PM
No one wants to recommend RoverGauge?
Originally Posted by pendy
I'm here for the D's
Old August 18th, 2015, 07:20 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Nah... I like hunting in the dark!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 18th, 2015, 08:01 PM
Except that time it didn't at Wintergreen.
idle
Stalling at Idle and switching gears at low speed BEIS Defender Technical Discussions 9 May 8th, 2013 02:33 PM
Stalling, stalling and more stalling !!!!!!!! DucatiChick Defender Technical Discussions 11 October 8th, 2012 04:59 PM
D90 stalling/soaring idle wicks Defender Technical Discussions 10 October 17th, 2010 04:56 PM
Stalling After Long Idle Time don Defender Technical Discussions 5 April 24th, 2010 11:31 AM
High Idle after Highway Cruise + stalling cellulararrest Defender Technical Discussions 3 October 11th, 2006 05:05 PM
