Cold idle. - Defender Source
Old April 28th, 2013, 09:55 AM
Cold idle.
So the other weekend I was with some othe truck owners and we noticed my truck has strange startup behavior.
Their trucks start, idle high and drop back to idle levels when warm.
Mine starts low and increases idle ... Via some surging to warm levels.
It's not causing me any issues, was just wondering if anyone else had experienced it.
Old April 28th, 2013, 03:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Might be the PROM program in the ECU. Many were upgraded to a cold start version-- I believe that may be the difference. Many use the 4.2 cold start prom-- super simple to upgrade-- 4-screws, I chip, plug and play...
Old April 28th, 2013, 05:00 PM
My guess is the temp sensor is running open loop.
I really need to get a rover gauge.
Old April 28th, 2013, 06:04 PM
rover gauge shows temp sensor is running properly.
I saw something about the plenum casting restriction around the idle control valve i might measure that.
I'll also check my PROM version ... can't recall what version I have.
Rough Idle when engine is cold Jon_Winningham Defender Technical Discussions 2 May 10th, 2011 05:07 PM
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold engine idle surges Bozman Defender Technical Discussions 4 May 22nd, 2007 09:21 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
