Cold engine idle surges - Defender Source
Old May 21st, 2007, 10:36 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I am sure this has been covered before, but here is my latest quirky thing:
The truck idles a little funny when it is warming up.
It surges between 1000-2000 rpms about 4-5 times before it stays at a smooth idle around 1000 rpms. A surge lasts about a second, and this usually only happens when you are decelerating to a stop, and only before it is completely warmed up.
After it is warmed up (about 5-10 minutes) it idles fine. I have a feeling this could be many things (mass air flow sensor, throttle position sensor, etc.) but something that I have not seriously looked into because it really only happens when the truck is warming up.
Any thoughts?
Old May 21st, 2007, 12:54 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I've never had that problem on the d90, but with my range rover it did that, and it was the IAC (Idle Air control valve) also known as the stepper motor. You can take it out and clean it. they sell all kinds of lubes for it at napa.
Old May 21st, 2007, 01:02 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I will take a look at that tonight.
Greg
Old May 22nd, 2007, 09:09 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Where is that?
I do not mean to ask a dumb question, but where is the stepper motor located?
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old May 22nd, 2007, 09:21 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
If I am not mistaken . . .
The plenum chamber is the large alloy piece on top of your engine with 3.9 on it. The stepper motor/air bypass valve is at the rear of this, on the left hand side. It has a few wires going to it, with a black multi plug on the end. The unit looks like a large black nut, on the end of an inch long cylinder.
engine, idle
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
