Cold Climates, Old Diesels and Syn 5W - Defender Source
Old January 3rd, 2016, 08:19 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Whats the general consensus on using a modern, low zddp, synthetic 5W-40 such as Rotella T6 in older push rod diesels? I put it in last winter and up into the middle of Summer-about 5000 miles. Sure starts easier at -5F using it.
When I replaced the head recently there was a valve cap missing a wedge shaped piece and three of the rocker arms needed replacement due to rough spots. Obviously the worst being the one riding over the awol slice o pie, which I found. Was the wear due to the 5W? Probably not but a mechanic I used to go to suspects modern synthetic 5W ruins old pushrod motors.
Use a syn 5W for Winter and add something like STP Oil Treatment that has ZDDP?
Thoughts?
Old January 3rd, 2016, 08:27 PM
The T6 should be as good an oil as is possible for the engine. They use roller lifters and need no special additives.
I've never seen wear in one unless it was massively abused. If someone used new, OEM valve caps, that could be a problem as they have a 100% failure rate. You need to use aftermarket hardened ones. You have not been able to get good genuine ones for years.
Old January 3rd, 2016, 11:56 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Rizlone makes a good ZDDP, I use it in my 300.
I'm using the DELO fully Syn diesel oil.
Old January 6th, 2016, 07:04 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Thanks guys. I replaced all of the valve caps with Turner's version. They looked different from what was in there, beefier and dark, not chrome.
Old January 6th, 2016, 10:23 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I use M1 5w-50 in my 90. It has higher zddp than many current oils, cf rated and is bmw high performance diesel approved. Mobil's tech help, once I finally got past the marketing types, said it was good for the application.
Roller lifters shouldn't have the problems that "flat" tappets do with reduced additives in some modern oils, but i prefer heavier weight, higher additive oils in my older vehicles.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 20th, 2016, 01:37 PM
Fender
Reinier
1991 D110
Just switched to the shell synthetic sure makes it easier to start runs good too!
diesel
EPA and VW diesels - 'dyno' and 'road' modes down_shift Misc. Chit-Chat 274 October 20th, 2017 10:26 AM
CT and diesels ECR Misc. Chit-Chat 1 September 29th, 2014 10:23 AM
NY and diesels ECR Misc. Chit-Chat 12 December 21st, 2011 11:58 PM
Parts, Service and Diesels in Atlanta atlcruiser The Vendors Loft 6 November 2nd, 2011 09:48 AM
Clearout of old stock 2 x 110 RHD diesels - $20,000 Firm the pair globallandrovers The Vendors Loft 4 March 6th, 2010 11:25 AM
» Defender Registry
Dennis
juddy
130
kellymoe
Add your Defender
