COIL (ignition) questrion - Defender Source
Old February 21st, 2006, 08:42 PM
okay not on a Defender so sorry. But my boss has a 95 LWB about 150K miles. Was headed home to eastern NC from the MTNS of Va, stopped cut off truck (all was well). tried to start and wouldnt. long story short got it back to the shop rumaged around and found a coil that "worked". Had replaced whatever was in (stock?) with an ACCEL coil this is the supposed culprit for the not restarting. he said the coil (ACCEL) was too hot to touch... It has stock ignition and those BOSCH Platnum plugs, I have told him about those things.
SO now the truck is running again I drove it today runs good as usual on the coil from the randompartsbin. Why would the ACCEL overheat causing the truck not to restart? I havent done anything to the truck just relaying what he told me so I am not really sure what the issue could be. But it seems that the only time the truck has had any issues is when it is being driven at long interevals on the highway. Is the ACCEL a shitty coil or what? thanks for any insight I Hope all this makes sense. thanks dudes
Old February 21st, 2006, 08:48 PM
robisonservice
John Robison
2008 Supercharged Range Rover
The Accel coil may have been designed for use in a car with points and a ballast resistor. Using such a coil in a Range Rover would overheat the coil and may fry the ignition amplifier. I suggest getting the correct Bosch coil. Coils are not generic, because some are made for one type of electronic ignition, some for another, while others are made for the two kinds of point systems.
Old February 21st, 2006, 09:43 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I would also check the dwell readings. A failing module may still work but the readings will be too high and may overheat the coil.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 21st, 2006, 09:45 PM
where are these located? I dont know anything about the 4.2 and RR's I assume its mostly the same as on my 3.9 but yeah...
Old February 21st, 2006, 10:37 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
There is a good writeup on the Solihul Society web site where a member changed the ignition module to a GM
http://www.solihullsociety.org/
Hope that helps
--Benjamin Franklin
Old March 3rd, 2006, 03:57 PM
Antonios
Antonios Hadjigeorgalis
No more
How do I check the dwell? I think my ignition module may be causing my intermittent stalling.
Miami, FL
Old September 7th, 2010, 08:00 AM
Bosch coil or Lucas coil?
coil
New STC1212G Amplifier Module Link Lead and Stock Ignition Coil nimbusnic For Sale - Parts 0 December 29th, 2008 04:54 PM
Who is the ignition module / pickup coil authority here? dnp Defender Technical Discussions 30 August 22nd, 2008 03:14 PM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
