Code P1191 - Defender Source
Old October 6th, 2015, 02:01 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Code P1191
Truck is running crappy today. Had the codes read.
P1191
Looked it up online and it seems to be an o2 sensor. See attached screen shot.
Anyone have any experience with this code? If it is an o2 sensor how do you know which one it is out of the 4 on a 1997?
Truck is suffering loss of power, runs rough and appears to be missing.
Name:	Screen Shot 2015-10-06 at 12.56.26 PM.jpg
Old October 6th, 2015, 02:09 PM
ezzzzzzz
Mark Garrenton
Downstream means post cat. These do not control fuel trim. That code indicates that both post O2S are not showing any signals so it indicates an open circuit possibility. It could mean both convertors are shot. Do they rattle when idling (usually when cold) or if you thump them with a rubber mallet or fist? If not, then it could mean a failed ECU. What are the symptoms exactly? Did this just suddenly happen?
Old October 6th, 2015, 04:05 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks Mark.
It just happened suddenly. Ran fine yesterday and this morning. Then went to doctor and came out and bam running like crap.
Cats are not making noise but I will check them.
Old October 6th, 2015, 04:52 PM
jafir's Avatar
jafir
Jafir Elkurd
That's a heater code
Old October 6th, 2015, 05:07 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
So what would that be Jafir?
Not sure what a heater is. Well I assume it is not the cabin heat.
Old October 6th, 2015, 11:32 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Okay so it seems either I have a bad cat or a bad o2 sensor.
Are all 4 of the o2 sensors the same? One site I found has upstream and downstream ones for different prices and places like Atlantic British just show one.
Do I need to buy a downstream one specifically or do they all do the same thing?
Thanks!
Old October 7th, 2015, 12:07 AM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by Tyler Wirken View Post
So what would that be Jafir? Not sure what a heater is. Well I assume it is not the cabin heat.
I'm assuming something in the heater circuit for the sensor. The sensors, wiring, fuses, relays, computers, etc.
I wouldn't think a bad cat would cause a heater code.
Old October 10th, 2015, 04:02 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Well changed out the O2 sensors downstream and no improvement.
Checked codes again. Two new ones now that were not present the other day.
P0300
P0302
OBDII reader said multiple misfires and misfire cylinder #2
But the P1191 code is gone at least.
It has new plugs and wires as of about 3 years ago so I assume it is either coil packs or injector. Anything else I should look at?
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Radio Code Help? ;) wicks Defender Technical Discussions 7 December 31st, 2009 07:59 AM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
