Code p1178 - Defender Source
Old August 31st, 2010, 02:29 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Code p1178
Truck is running rough at spots and has a slight ping/knock under load. Also just threw code p1178.Just searched and found o2 sensor. Before I drop the $$ anyone have any other ideas and if it is o2 where is the best place to get them. Thanks
Old March 13th, 2012, 08:53 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
Code P1178
What was your solution to this (codeP1178) and the knocking?
My D-90 threw the same code today and has been ticking real bad the past few weeks since I started driving it again. I also had the following two error codes as well.
P1313 Misfire likely to damage catalyst bank A
P1314 Misfire likely to damage catalyst bank B
Rob
Navy. It's not just a job, it's a job on a ship.
Old September 12th, 2012, 09:22 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
CEL was on and it scanned P1178. I reset it and it hasn't come back on yet but it probably will. From what I've read it could be the MAF Sensor, Oxygen Sensors, Vacuum/breather hoses, fuel filter, air filter, injectors? If anyone else has had this code how did you do to fix it? Thanks.
Old September 14th, 2012, 08:15 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
It sounds like you probably have an intake leak. How is the idle? Is it high? Check the condition of the breather hoses for sure, and don't forget to take a look at the hose from the intake plenum to the fuel pressure regulator. Also, check for loose hose clamps on the breather hoses (and other intake hoses).
Old September 15th, 2012, 10:42 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Idle is not high, does idle at 1000 RPM sometime for some reason. I think I've replaced just about every breather hose. Will check that fuel pressure regulator hose. The code hasn't come back after 50+ miles so maybe I lucked out. Thanks.
Code P1178 NashvilleRedD90 Defender Technical Discussions 1 July 2nd, 2007 12:56 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
